Old 09-27-2013, 08:33 PM
disturbed one's Avatar
disturbed one disturbed one is offline
Vehicle: 2011 Dodge Ram 1500
Color: hunter green pearl coat
disturbed one is on a distinguished road
Default Bakflip f1
just ordered a bakflip f1 today and will install it when i get back home hopefully in a week or 2,i have line x spray in bed liner and was wondering as to where to run the drain tubes? I have a hole on each side near the top of the bed sides,would these holes be ok to run the drain tubes into?
Old 09-27-2013, 10:25 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
There's plastic caps near the bottom of the bed stake pockets that you can pull out and run the tubes into. I don't think the ones at the top go down all the way.
Old 09-28-2013, 12:19 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
This is where I ran mine on my 2012 ram.
not sure on the 2011's however on my 2012 the did go all the way down, I had the linex in mine as well and the shop that did it just sprayed right over the plugs and did not pull the plastic/rubber piece out I did not want to pull them out and chance cracking the liner or something so I looked for another solution and climbed under the truck and was able to verify the ones at the top went all the way down so that is where I ran the tube too.
As stated though this was one a 2012, might be slightly different on a 2011 just climb under the truck and look up and see if you can see the holes or not if you can you are good to go, if not you may want to find another solution..
thanks
Jeremiah
Old 09-28-2013, 11:44 AM
The Crow 1994's Avatar
The Crow 1994 The Crow 1994 is offline
Vehicle: 2013 1500 Big Horn Crew 4x4
Trim Level: Hemi 5.7L w/8 Speed
Color: Copperhead Pearlcoat
Rep:56
The Crow 1994 will become famous soon enough
This is where I located my drain tubes on my '13 Big Horn with the BakFlip VP tonneau cover. My Linex dealer used the holes in the front of the bed that were plugged with plastic caps. The installer drilled small pilot holes, big enough to barely fit the plastic tubing into, and then sprayed the liner.
Mod List: Line-X Platinum Spray-On Bedliner, BakFlip VP Tonneau Cover, TufTruck 1223-V HD Coil Springs, Bilstein 4600 Shocks, Air Lift 1000 Air Bags, Air Lift Wireless One Remote System with On-board Compressor, & Weathertech Digital Fit Floor Liners
Old 09-29-2013, 07:18 PM
after examining the holes near the top of the bed they do in fact open up so i can run the drain lines through them with out having to try and find the other drain holes that were sprayed over with the bed liner
Old 09-29-2013, 09:59 PM
eethomas's Avatar
eethomas eethomas is offline
Vehicle: 2012 Ram Laramie Longhorn
Trim Level: Longhorn
Color: Black & Gold
Rep:15
eethomas is on a distinguished road
When I installed my Roll-N-Lock cover, I ran the drain tubes in the slot behind the tie down hooks.
Eric Thomas
2012 Laramie Longhorn
Old 10-07-2013, 10:03 AM
got the backflip f1 installed today and it looks great!!! the ruber seals on top of the bed rails look like they need the sun to heat them up so the get a better form fit but other than that i love it
Old 10-10-2013, 03:18 AM
Silvercreek's Avatar
Silvercreek Silvercreek is offline
Vehicle: 2013 Laramie
Trim Level: Longhorn Crew Cab
Color: White/Gold
Rep:487
Silvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of light
I used a heat gun on low heat to heat up the rubber seal. A hair dryer will work well also.
I will soon be mounting a BakFlip F1 on my new Dodge Longhorn Limited.
"One Small Step For Man, One Giant Leap For RAM Fans"
4th Generation - 2013 RAM Laramie Longhorn
*** US Army Retired - 11B40 - 1964/'85 ***
Old 10-11-2013, 01:57 PM
that's where I ended up running mine.putting them in the top holes kinked the hose too much
Old 10-11-2013, 01:59 PM
its been raining here for the past few days and there is definitely water coming in where the rubber seal is not formed tight to the bed rail so after it quits raining i will try the hair dryer trick
