Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 09-28-2013, 12:47 AM
Yotaconvert Yotaconvert is offline
Vehicle: 2013 Ram
Color: Black Baby
Rep:172
Yotaconvert has a spectacular aura aboutYotaconvert has a spectacular aura about
Default SB Intake installation heads up for 2013 owners
I just spent about an 4 hours installing this intake....Why 4 hours well we ran into a slight issue with the parts in the kit.
My truck has 4 mounting bolts for the old intake box/support.
When you install the new one they give you a long bolt to install it back into the existing hole in the frame.
I followed the directions and blindly used their supplied hardware. I found out that my mounting bolts were fine thread and theirs were coarse; resulting in a set of mangled stripped out threads in the frame.
I had to get a set and rethread them and a new bolt to fix the issue.
I am assuming that SOME of them have these fine thread bolts where some have coarse. I have found a few anomalies like this so far on my truck so maybe I just got some spare parts bin scerws
Either way just be cognizant of the thread types when installing ANY companies supplied hardware or else your 1 hours install could become a 4 hour ordeal like mine lol
Otherwise the kit is BAD AZZ sounds great and makes the throttle more responsive.
2013 Black Beauty
-Spyder Halo/Projecter/LEDs
-SB CAI
-Flowmaster 40
-Bullydog Hemi GT
-MB Rims (cuz im cheap lol)
Old 09-28-2013, 12:57 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
as stated in your other thread
thanks for the heads up I am sure this will be useful info as S&B is a big name around here and I am sure someone else will run into this issue
Thanks for sharing
Jeremiah
Old 09-28-2013, 10:00 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
Thanks for the head's up. Hopefully you just saved someone else from going through what you did.
Exco
Bill
