Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 09-29-2013, 12:25 AM
trainguy's Avatar
trainguy trainguy is offline
Vehicle: 1996 Dodge 2500
Trim Level: SLT Laramie
Color: White with Gray
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Rep:38
trainguy is on a distinguished road
Default Silencer ring removal?
I have 1996 Dodge 2500 Cummins 5.9l and am looking to make it sound a little better.
I have heard removing the silencer ring can make it whistle a lot more.
Will removing the silencer ring on the turbo hurt the bushings?
Thanks,
Trainguy
Old 09-29-2013, 03:26 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Removing the silencer ring will definitely give you a lot more turbo whistle. I believe on your truck it's just clamped on so it's easy to get off and possible to put it back on if you want to. It shouldn't hurt anything inside the turbo at all, it's mainly just for sound and I've read that it does help with air flow slightly. Although I haven't heard of anyone reporting any power loss when taking them off. So I wouldn't worry about that.
Old 09-29-2013, 09:35 AM
trainguy's Avatar
Rep:38
Thanks for the info, I think I'll try doing it today. It's sunny here today, perfect weather.
Old 02-22-2014, 09:59 PM
mikerodrig27 mikerodrig27 is offline
Vehicle: 1998.5 Dodge Ram 2500 Cummins
Color: Two Tone Red Silver
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
mikerodrig27 is on a distinguished road
There is a grove that a circlip sits in. You have to remove that (I'd use a pick or flat head screw driver) and then the ring should be free to come out.
