Adding a Mopar Integrated Trailer Brake Controller - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 09-30-2013, 01:16 PM
vancat74 vancat74 is offline
Vehicle: 2015 Ram 1500
vancat74 is on a distinguished road
Default Adding a Mopar Integrated Trailer Brake Controller
Has anyone added the Mopar Intergrated Trailer Brake Controller to their after the purchase of the truck. I recently bought a travel trailer and was planning to add the Mopar brake controller, but my dealership want 238.00 for the controller and around 250-360 to install it or if i install it they want 150 to flash the computer. This seems way to high to me. Is it that difficult to install yourself?
Old 09-30-2013, 01:46 PM
Billacuda's Avatar
Billacuda Billacuda is offline
Vehicle: 2016 Ram 1500
Rep:113
Billacuda will become famous soon enoughBillacuda will become famous soon enough
I would just buy an aftermarket for less than $200 including harness and install it yourself. My Tekonsha Prodigy P2 and 2013 wire harness cost me $166 total.
2016 Ram 1500 Laramie 4x4
2015 Dodge Grand Caravan R/T
Old 09-30-2013, 01:49 PM
Yeah I agree, I am looking at a Prodigy P3 with harness for the same price. I really like the factory look but that is way to much money.
Old 09-30-2013, 02:13 PM
mineralram's Avatar
mineralram mineralram is offline
Vehicle: 2017 Dodge Ram
Color: Black Pearl Metallic
Rep:176
mineralram has a spectacular aura aboutmineralram has a spectacular aura about
Be very careful i have heard alot of 2013 owners having problems adding aftermarket controllers only to find out in the end that the 2013's will not run them.
Old 09-30-2013, 02:52 PM
There should be no problem, I purchased the wiring kit for the 2013. I would buy the mopar kit in a heartbeat but 500 or more is crazy.
Old 10-01-2013, 12:00 PM
rawhide007 rawhide007 is offline
Vehicle: 2013ram1500 express,3.92,6sp.
Trim Level: ST express
Color: red
rawhide007 is on a distinguished road
Angry
Don't spend money on it. My 2013 express has the intergrated controller,it is useless,because there is no sensitivity adj. when i apply brakes there is a delay before the trailer brakes apply and then it jerks both the trailer and truck.I'm very disgusted with this truck. The cheap metal latch on the console rattles like a dime in a tin cup.
Old 10-01-2013, 12:11 PM
CharlieL CharlieL is offline
Vehicle: 2013 Ram 4x4 Crew Cab
Rep:116
CharlieL will become famous soon enoughCharlieL will become famous soon enough
I disagree about the integrated controller, which mine came with from the factory. It's easy to get properly adjusted, the display is in the EVIC. I have no delay before the brakes apply & have learned that by changing the setting by a 1/2 increment when my trailer is empty or near empty, it performs flawlessly according to the weight. A real advantage of the integrated is the display of all info in the EVIC.
My suggestion is to be careful about what you buy & ensure you do your research. I've read on here both views - folks with real problems with adding an aftermarket & others whose install with an aftermarket went flawless.
Old 10-01-2013, 12:45 PM
countryboyloaded countryboyloaded is offline
Vehicle: 2011 Ram 1500 Laramie Longhorn
Trim Level: Laramie Longhorn
countryboyloaded is on a distinguished road
Good to know! I was thinking if doing this also
Old 10-01-2013, 01:02 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Don't play games when it comes to a break controller it's not worth losing your life just because you were cheap. the factory one is great I have had no issues with it. and there is a chance it might just plug in and work. My mechanic installed one in his and he did not have to flash the computer. it doesn't hurt to try. I would defiantly recommend getting the Mopar one that goes with your truck.
Besides it looks better blends into the dash.
Old 10-01-2013, 01:10 PM
Rep:2929
The proper Mopar looks better & does display on the EVIC
it will also increase the value of your Ram, if you ever decide to sell it
Go to the eTrailer website & look up the Tekonsha Prodigy P2 for the 2013 Ram
all the facts are on that website
if you want the 3rd brake light to work with it, there is a add on harness, required in California
