Adding a Mopar Integrated Trailer Brake Controller - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 10-01-2013, 05:06 PM
tak1973 tak1973 is offline
Vehicle: 2004 Ram 2500 Quad Cab 4x4
Color: Maroon
Rep:35
tak1973 is on a distinguished road
I purchased the factory unit from a seller on eBay. It installed easily, and my truck recognized it right away with no trip to the dealer.
I modified the mounting process of the bracket slightly, however. The factory option calls for installing screws from the center of the truck out. I could not see an easy (or possible) way to do this without taking apart most of the dash. I drilled holes in the bracket near the existing mounting holes, and used 2 #6 tek screws to mount it under the dash. Piece of cake...
Old 10-01-2013, 05:34 PM
Rep:2964
this shows how easy it is to remove the center dash bezel
this is a video about installing the after market brake controller
Old 10-01-2013, 05:36 PM
countryboyloaded countryboyloaded is offline
Vehicle: 2011 Ram 1500 Laramie Longhorn
Trim Level: Laramie Longhorn
countryboyloaded is on a distinguished road
What about doing this on an 11? The slot is to the left of the steering wheel on the bottom of the dash. Anyone messed with that?
Old 10-01-2013, 05:41 PM
The Hemster's Avatar
The Hemster The Hemster is offline
Vehicle: 2013 Dodge Ram Express
Color: Mineral Gray Metallic
Rep:69
The Hemster will become famous soon enough
Originally Posted by rawhide007 View Post
Don't spend money on it. My 2013 express has the intergrated controller,it is useless,because there is no sensitivity adj. when i apply brakes there is a delay before the trailer brakes apply and then it jerks both the trailer and truck.I'm very disgusted with this truck. The cheap metal latch on the console rattles like a dime in a tin cup.
The sensitivity adjust is the + and - button. It integrates with the digital dash read out. Just go into the menu and you should be able to see it. I complained to the dealer and got mine installed for 290.00 after tax and labor.
Old 10-01-2013, 05:42 PM
Rep:69
It's a different control than the 13. They changed it for 2013. I heard it's an easy install for the 2011.
Old 10-01-2013, 05:44 PM
Rep:2964
the 2011 is pretty easy too, basically the same as the 2010 model
there may be a wire color change
https://www.youtube.com/results?sear...be.IlUOUdCqI3o
this is how one guy worked with the 2012 brake controller & the software to make it show up on the EVIC
Old 10-02-2013, 07:20 PM
Nburd's Avatar
Nburd Nburd is offline
Vehicle: 2013 ram 1500
Trim Level: Express crew
Color: Mineral gray
Rep:231
Nburd has a spectacular aura aboutNburd has a spectacular aura aboutNburd has a spectacular aura about
I did mine last weekend. Installed in 30 minutes. It actually worked without flashing. You just cannot see the display of the output (I have the 7" evic). I debated having it flashed. The dealer did it for free. I could see the gain. Setting on the evic. Flashing gives you the output in a gauge when a trailer is connected, tracks trailer miles and gives you 4 custom options for different gains. At least on the 1500 express.
I like it, I tow one trailer with electric brakes. I have not connected it yet.
Install it yourself. It's easy. Watch your fingers. The steel under the dash is razor sharp. I ended up with two band aids. A 7 mm box end wrench is needed for sure.
Nburd.13 Ram 1500 Express Crew 4x4. Mineral Gray, Chrome 20s, Cloth, Uconnect 5.0, 7" Evic
Old 10-02-2013, 07:24 PM
Nburd's Avatar
Color: Mineral gray
Rep:231
A great idea as those screws are a bear. Another idea, drille the bracket through and install u shaped speed nuts on the factory steel under the dash. Then a ratchet will screw the screws in the easy way through the bracket and firmly attach to the steel.
Old 10-03-2013, 05:30 PM
Carfreak 7186 Carfreak 7186 is offline
Vehicle: 2013 Ram 1500 Sport
Color: Copperhead Pearl
Rep:26
Carfreak 7186 is on a distinguished road
I'm just wondering, I want to install factory built in unit in my truck. When removing the blank plate in the dash, where the unit is mounted, is the plug there to just plug the unit in? I am dreading the thought of having to take my center console apart, to run the wires to the back of the controller unit in the dash.
Thanks
Old 10-03-2013, 06:53 PM
Nburd's Avatar
Color: Mineral gray
Rep:231
Yes the plug is there. It plugs into the back of the blank. Just plug in the new switch and install the module and two plugs into module.
