Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Dodge Ram Aftermarket Brakes
Dodge Ram Aftermarket Brakes Aftermarket Big Brake Kits. Not for discussion of General Brake Maintenance.
Old 01-17-2015, 08:48 PM
t-johnson19881 t-johnson19881 is offline
Vehicle: 2001 dodge ram
Color: forest green pearl
t-johnson19881 is on a distinguished road
Default blew the rear brake line on my 01 2500
So I recently had my rear brake line blow on my 01Cummins behind the fuel tank haha seems to be the common place neways does neone no where to find that part that the hard line goes into n it comes out that high pressure rubber down to my rearend I can find the hose but I need to replace that bracket where they connect together or can I just forget that joiner n just run it all hard line?? Help
Old 01-19-2015, 12:59 PM
prattman prattman is offline
Vehicle: 2012 Dodge Ram 1500 QC 4x4
Rep:23
prattman is on a distinguished road
I ordered an EGR Stainless Steel Pre-bent brake line kit from Circle Track Supply for my old 1998 Dodge Cummins 2500 4x4. I had a shop do the swap. I don't remember what I paid for the install as I had other work done at the same time. The line that usually rusts out is the brake line that runs down the drivers frame rail next to the fuel tank as you've discovered. Here's the link for the kit: http://www.circletracksupply.com/pre...s-2wd-4wd.html . For $349.95 I think it's worth it. Do it once and be done with it. Also see this post: http://www.ramforumz.com/showthread....ty+brake+lines -Glen
