Old 09-30-2013, 09:31 PM
OneRoe OneRoe is offline
Vehicle: 2010 Ram 1500 SLT
Trim Level: SLT SPORT
OneRoe is on a distinguished road
Thanks guys!! I reapply appreciate your help. REALLY!!
I can't get the truck into neutral as it won't shift due to it not starting up I guess. So how can I get it into neutral? Also, I've tried to jump it with another vehicle and that did nothing. One more thing, I have no idea what a starter relay is (sad, yeah I know). What am I looking for so I can try to swap that out? Any other ideas, please shoot em at me thanks!
Old 09-30-2013, 09:36 PM
JohnnyDollar's Avatar
JohnnyDollar JohnnyDollar is offline
Vehicle: 2012 Ram 1500 Quad Cab
Trim Level: Lonestar
Rep:216
JohnnyDollar has a spectacular aura aboutJohnnyDollar has a spectacular aura aboutJohnnyDollar has a spectacular aura about
I think if you turn the key to the on position, it will let you move the shifter
2012 Ram 1500 QC Lonestar Edition - La Bestia Defavorable
Old 09-30-2013, 09:37 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
You should be able to get it in to neutral by turning the key to the run position, stepping on the brake, and shifting it down. It doesn't need to be running.
The starter relay essentially looks like a 1"x1"x1" cube in the fuse box (TIPM) under the hood. Pull out your user manual and find the fuse box diagram. That will tell you which one is the starter relay. Just pull it out and put one of the other relays that are around it in it's place. Just make sure you don't pull one out that will hinder the truck from running as well such as something for the fuel pump or ignition.
Old 09-30-2013, 10:38 PM
Nope. It won't let me move the shifter. The brake won't even go down. It's like it's locked or something.
Old 09-30-2013, 10:41 PM
Hey Brandon, thanks bro! So, basically im looking for the fuse box. I'll try that!
