Emissions Calif. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 09-30-2013, 08:50 PM
genewants to know genewants to know is offline
Vehicle: 1996 ram 1500
Trim Level: club cab
Color: driftwood
genewants to know is on a distinguished road
Default Emissions Calif.
Went in today for Calif. Emissions test on my Ram 1500, 5.2l 318 4x4.
The test failed on Nox at 15mph it passed on 25mph. I recently repaced the furel pump and fuel filter. 188,000 miles still runs strong. Any ideas on what I may try to do in order to pass this state test for registration renewal.
At 15mph @1451 rpm measured 1265 NO (PPM) MAX Allowable is 999.
Thanks for any assistance
Old 09-30-2013, 09:15 PM
1stRAM2012's Avatar
1stRAM2012 1stRAM2012 is offline
Vehicle: 2015 Ram 2500
Color: Black on Black on Black
Rep:123
1stRAM2012 will become famous soon enough1stRAM2012 will become famous soon enough
I don't know how to help but have to ask what emission test are you doing I have never had to drive for a smog test
MODS in profile
Old 09-30-2013, 11:48 PM
Color: driftwood
Thanks
Not actualy a drive test they just run the vehicle on a state approved test stand at the two indicators 15 and 25 MPH. They check and measure CO2 and O2 (%) HC (ppm)CO (%) and NO (ppm). I failed on NO 1265 (ppm) vs. allowed 999.
Maybe I will try carb. adjustment and run a can of Sea Foam or Lucas through the fuel tank. It's a 1996.
Old 10-01-2013, 01:06 AM
1stRAM2012's Avatar
Rep:123
ahhh now I gocha had the same prob with my s10 I ran seafoam through it agjusted it to a high idle let it burn everything out for about 4 hrs adjusted the carb till it loved like it wanted to die. Took out the pcv and I barely passed. Don't know if taking out the pcv helped but my dad told me to do it so I did. Also don't know if you can get away with that in Cali...worth a shot
MODS in profile
Old 10-01-2013, 11:37 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:57
Wh1t3nukle will become famous soon enough
You don't have a carburetor on this engine. It's MPI, multi point fuel injection, which is another way of saying EFI. So, you can't adjust it as the PCM (computer) controls it.
What is your tire size?
Go do a tune up. This means replace spark plugs, wires, distributor cap, and rotor. DO NOT TRY TO TURN THE Distributor thinking it will change timing. It does not!! Get everything from Napa as these engines in stock form don't need anything fancy. I would do SEAFOAM before the Tune Up. I'd also do a oil/filter change after the tune up.
Another low cost thing to change out is the PCV valve. It is located on the valve cover. ONLY buy this part from the dealer. Specs on the dealer part are different from ones at the general auto parts store. This is like $10 part. Get new valve cover grommets too just in case the old ones are trash.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 10-01-2013, 03:26 PM
Color: driftwood
Thanks for the advise. I will do the tune-up and get the PCV valve from the dealer.
Tire size is LT245/75R16 Dunlop Rover
Again thanks for the Info.I appreciate it.
