Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 10-01-2013, 08:30 AM
craigsredram's Avatar
craigsredram craigsredram is offline
Rep:61
craigsredram will become famous soon enough
Default My 13 RAM struggled to start this Morning, barely runs.
So I went outside this morning (0540) to head out to PT. It was about 42 degrees out so it was cool out. I went to start my RAM and it took many turn overs for it to start, once it got started, it sounded like it was running on 2-3 cylinders. My RAM only has just over 5,000 miles on it. I had to move it so I could get to my wife's car so I wouldn't be late to PT. Once I put the truck in gear it almost died and had no power and it had a massive vibration, I'm talking shaking the dashboard violently.
When I came back from PT, it sounded a bit better but it smelled like it was dumping fuel into the motor and it still had that violent vibration.
I am going to be calling my Salesman so he will work with the Manager to get my truck looked at and get a rental. I am not impressed so I hope RAM can get it sorted out properly.
Old 10-01-2013, 09:47 AM
Rexer's Avatar
Rexer Rexer is offline
Vehicle: Ram 1500
Rep:207
Rexer has a spectacular aura aboutRexer has a spectacular aura aboutRexer has a spectacular aura about
Sounds pretty bad, I'd get it towed to the dealership ASAP! Hope it turns out to be a quick easy fix
Old 10-01-2013, 09:56 AM
CharlieL CharlieL is offline
Vehicle: 2013 Ram 4x4 Crew Cab
Rep:100
CharlieL will become famous soon enoughCharlieL will become famous soon enough
Your Ram's symptoms sound similar to what mine experienced at 3,000 miles. Temperature had nothing to do with it, tho. It acted like it was missing terribly, as if the timing was way off. Turned out to be not firing in one cylinder and the PCM had to be replaced. Not a big deal & has worked just fine since. I was just glad it happened a few weeks before a long trip - not while I was on the road.
Old 10-01-2013, 08:20 PM
Rep:61
So today I took my truck into the dealership and they gave me a rental car to dub around in. So far they have treated me well. I have nothing bad to say about my RAM Dealership from Sales to Service so far, we'll see. The Service Manager did say that if there is anything seriously wrong with my truck, like the engine seizing, he said Chrysler will be buying me a new truck.
But they will diagnosis it tomorrow and give me a call to let me know whats wrong with it and their plan of action.
Old 10-02-2013, 09:21 AM
Fliehigh's Avatar
Fliehigh Fliehigh is offline
Vehicle: 2013 Dodge Ram 1500
Fliehigh is on a distinguished road
I look for ward to hearing what the Diagnosis was and how the resolved it.
Old 10-02-2013, 05:53 PM
Rep:61
So I got my truck back today. They said the computer threw out a Cylinder Misfire Code (Duh), so they reset the computer and the code went away. They looked for a TSB for the issue, there wasn't one. So they drove it a whole 5 miles and the issue didn't come back.
I have a feeling it will come back. A ECU doesn't just throw a code for no reason.
Old 10-02-2013, 09:45 PM
Rep:100
Your gut's probably correct. When my PCM went out, the check engine light came on & I was told it was misfiring on one cylinder.... No TSB, but replacing the PCM solved the problem.... Maybe you will have better luck!
Old 10-03-2013, 07:35 AM
Rep:61
It did it again this morning. Check Engine Light is back on. Awesome
Old 10-04-2013, 05:30 PM
Rep:61
Update: Yesterday, I took it back to the dealership. I talked with the Mechanic that is working on it, I explained to him the problem and what it was doing (complete with sound effects) and he had an idea what was wrong with it but wanted to hear for himself. So they took my truck and let it sit overnight so the engine would be cold (it does it when the engine is cold). They heard exactly what I was talking about, the Mechanic said it was horrible.
So the Mechanic troubleshot what he thought was wrong with it. Nothing. They are stumped. They are going to go more in-depth tomorrow.
Old 10-08-2013, 03:23 PM
Rep:61
So they think its the TIPM acting up. So they are going to replace it first and see if that fixes the problem.
