Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 09-08-2013, 04:10 AM
Pacheco911 Pacheco911 is offline
Vehicle: 1998 Dodge Ram 1500
Color: Dark Green
Pacheco911 is on a distinguished road
Default O/D button doesnt light up. Working?
I cant really tell if the O/D is working on my 1997 dodge 1500 360 4x4, when i press the button it doesn't seem to do anything.
Old 09-08-2013, 05:22 AM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
If you push the button look on the dash in the center. It should light up and say OD OFF. R...
Old 09-09-2013, 01:24 AM
Color: Dark Green
There is no light that turns on anywhere on the dash, could be a broken wire? or ?
Old 09-15-2013, 09:29 PM
mtparker18 mtparker18 is offline
Vehicle: 2001 2500
mtparker18 is on a distinguished road
Go on the highway at about 60-70 MPH, press the button and see if it downshifts, if it does it's working.
Completely stock other than a dumped super 40, projects in the works!
Old 10-06-2013, 11:05 AM
83camocharger's Avatar
83camocharger 83camocharger is offline
Vehicle: 1996 Dodge Ram
83camocharger is on a distinguished road
my button used to light up orange when i pushed it and then one day it quit. but never had light come on the dash. The only way to tell is about 60mph. when you turn your key off it will reset the button for you incase you forget.
Old 10-06-2013, 12:57 PM
Rep:177
So did my 98, it went out, but it is out. It's my old farm truck that sees no more than 6 miles a month on the road (rest of the time on the farm). If at 60 you see the rpm shift you still should have it, your light burned out. My 99 diesel still works, the 97 360 magnum still works. Note though, your 96 is not electronic transmission like 97 and newer..............that is why your 96 works and my 98 doesn't (97 and above electronic tranny). R...
Yeah, you can listen and do it manually. R...
