tonneaucovered.com
Old 10-01-2013, 01:39 PM
dabranco dabranco is offline
Vehicle: 1996 dodge ram
Color: red
dabranco is on a distinguished road
Default Sheep sex
OK. so here is the problem. Do you grab the wool or what do you hold on to???
SO the real issue is that I got the a518 (46re) rebuilt oin my 1996 Dodgge ram 2wd with a 5.9. I am experiencing a shift issue, Last night I pulled a code of P0783 no 3-4 shift torque converter locks up in third I have to hold the pedal steady to get it to shift from 1-2-3. Or I can shift it manually.
Fluid is full, and clean, all sensors were working before removal (from what the trans guy said). The truck was neglected look at my "boobs" thread in the intro. All clutches were good except for the ones controlling 2nd gear before the rebuild. the inside has new steels and clutches as well.
Old 10-01-2013, 05:37 PM
1stRAM2012's Avatar
1stRAM2012 1stRAM2012 is offline
Vehicle: 2015 Ram 2500
Color: Black on Black on Black
Rep:123
1stRAM2012 will become famous soon enough1stRAM2012 will become famous soon enough
did you check this he fluid with vehicle on or off
MODS in profile
Old 10-01-2013, 08:57 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:93
If a stock transmission, you must check trans fluid with engine running, trans in neutral, preferably warmed up.
Old 10-02-2013, 01:43 AM
1stRAM2012's Avatar
Rep:123
well thats where i was going with that so yeah what he said^^^
MODS in profile
Old 10-02-2013, 01:21 PM
Color: red
Check trans fluid with engine running in neutral and fully upto temp. Fluid is full all connecters hooked up and it is clean.
Old 10-02-2013, 02:11 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:446
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I've heard, in Scotland, the sheep farmers wear knee high boots, can't imagine why, though. Warmed up,in park, at idle, hind leg in each boot, dipstick inserted.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 235,000 miles To Hell and back. 14.2/96 mph NEDW
Old 10-02-2013, 02:41 PM
Color: red
nice thing is the hole is already lubed up
Old 10-02-2013, 02:56 PM
1stRAM2012's Avatar
Rep:123
it may be an issue from the re build. when i went to my advanced course i rebuilt a 4l80e and if everything isnt within the precise measurements taken with a micrometer then something will fail. also some transmissions have little metal balls that sit over holes in channels fluid pushes them up with the correct amount of pressure and sends them down the channels to engage different clutch packs. if one of those is missing then you are always flowing fluid to that channel and that clutch pack. so you are trying to engage 2 gears at ones...obviously this doesnt work
MODS in profile
Old 10-02-2013, 03:20 PM
Color: red
I know the valve body is sealed unless you pull it apart but I kept it as a whole unit. Everything is with in specs as well all measurements for what the factory calls for.
Old 10-02-2013, 03:42 PM
1stRAM2012's Avatar
Rep:123
the only thing left i can think of is the shift solenoids or the torque converter itself ( i highly doubt the tc but never know)
MODS in profile
beater, fart, nipples, peter
