Old 10-03-2013, 12:44 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
I heard they shag 'em facing a cliff so they'll push back. Anyway, yeah, it sounds like an issue in the valve body. For some reason I'm thinking maybe the line pressure is too low.
Old 10-03-2013, 12:51 AM
dabranco dabranco is offline
Vehicle: 1996 dodge ram
Color: red
dabranco is on a distinguished road
Yea I am thinking shift solenoid I did the horn relay swap and ruled out the relay. If it was line pressure I shouldn't be getting a 1,2,3 shift the delay could be fault internals in the valve body damaged spring or stuck (varnished) check balls. As for the torque converter it locks up at about 1700-2100rpms in third gear which should be normal. I can live without overdrive just nice to know I went from 100miles on a half of a tank to 100 miles on 1/4. So probably will replace the valve body, and the TV cable as well.
Old 12-18-2013, 02:12 AM
Samuel- Samuel- is offline
Vehicle: 2012 Ram ST
Samuel- is on a distinguished road
Not all sheep have wool, so you can't count on grabbing the wool.
Wearing a kilt is the best practice, that way they don't hear the zipper.
My two Scottish Soay rams.
beater, fart, nipples, peter
