Old 10-01-2013, 02:29 PM
jbatch jbatch is offline
Vehicle: 2002 Ram Sport
jbatch is on a distinguished road
Default crazy codes?
my 2002 4.7 is throwing 0032 (high voltage upstream sensor) and 0037 (low voltage downstream sensor) the guy at advance auto has never seen that before... the truck runs perfectly fine but i need to pass inspection. i have a y-pipe after the cat with no mufflers... could my cat be bad? i replaced the downstream sensor and its still reading the same codes 200 miles later... any ideas?
Old 10-02-2013, 07:30 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Sounds like a circuit problem, wires may be open/short
http://www.obd-codes.com/p0032
http://www.obd-codes.com/p0037
Side note: it may appear to be running fine, but thats probably because the PCM defaulted input for O2's since it cannot recieve its input. usually you will see a decrease in MPG
Old 10-02-2013, 11:54 AM
I'll check all the wires. Thanks
Old 10-02-2013, 11:55 PM
My shithead friend changed the wrong o2 sensor. Lol. Gonna swap em tomoro and see of it fixes
Old 10-03-2013, 07:32 AM
tjbiker031's Avatar
Rep:118
Well you can change it if you want. Personally it sounds like a circuit problem to be and i would (if i were in you shoes) test the circuit with a mulitmeter and verify the circuit is good.....90% of the time these sensors dont go bad unless you had a rich condition for a prolonged period of time.
Edit: each code is for the Bank 1 sensor (drivers side) for both up and down stream. and you want to make sure the cat is operating properly (this can be done by using IR thermometer.)
