Old 10-01-2013, 05:02 PM
acerplacer acerplacer is offline
Vehicle: 2012 Ram 1500 Crew ST 4.7 V8
Color: Metallic Gray
acerplacer is on a distinguished road
Default Chip on 2012 Ram 1500 ST 4.7
Hi all its been a year. Has anyone had any success with any mods on the 2012 4.7?
Old 10-01-2013, 09:22 PM
Asur Asur is offline
Vehicle: .
Rep:4371
what are you asking as far as mods, I have done on my 4.7 a ton of mods, looks at my build.
http://www.ramforumz.com/showthread.php?t=112109
Old 10-02-2013, 02:05 PM
Sorry I should have been more clear. Any recommendations for chips on the 2012 4.7?
Old 10-02-2013, 03:19 PM
Vehicle: .
Rep:4371
Right now your choice is the Bully Dog, I have no idea if Diablo with release anything for the 4.7. The 2 units I am talking about are not chips but Tuners, The BD will crack the encryption on your ECU and encode it with either a standard tune (87+ Octane needed) or a performance Tune (91+ Octane needed), 15+ hp and 30+ hp, so at the wheels you will get maybe 10 or 20, most will not feel a 20hp gain. With a free flow exhaust, TB, good high flow filter, you should start to feel it. Many are getting this tuner specifically for the shift points it provides as the stock ones suck. You can also modify these, turn off your drl's, read and reset your codes. and a few other things. Hope this helps.
Old 10-02-2013, 10:54 PM
Hornet Hornet is offline
Vehicle: 2013 RCSB Ram
Rep:470
As Asur says,you won't notice much from bolt-ons with-out a tuner.
I have the Airraid CAI kit/ Magnaflow cat back dual exhuast and a ported 78mm throttle body on my 13's 4.7 and other then making my wallet lighter by close to 1500 bucks the mods aren't really noticable.
Just a heads up if your doing the exhuast,if you go hog wild on pipe size,the truck will lose percious bottem end torque,it gets it back above 4,000,but if you need grunt i'd stay away from a dual exhuast style kit.
Do a muffler on the stock system if you have the 3" pipe single exhuast,you'll be happier and money ahead.
Nobody says anything about doing the cabin air filter mod,i find it to be one of the best mods i've done to mine.
Keeps the interior noticably cleaner with less dust.
If we're listing mods (plus the ones listed above) , mines been dropped 2" front and rear , Mopar mudflaps , colour matched bumpers / grill , upgraded 17" rims , Mopar tonnue cover / Mopar bedrug / Mopar bedlight kit , Stampede chrome bug deflector / Weathertech clear in channel vent visors , debadged (courtesy the better 1/2) , manual sliding rear window , switched to Redline synthetic oils in motor and rear diff at 1500 miles.
Still want a tuner,but that might never happen for us 13 guys with a 4.7.
If you want mods you can feel,look at a torque convertor swap and deeper rear gears,they'll give you something you can feel,and if you don't get carried away on convertor stall speed and how deep the gears are, it'll still be daily drivable.
