Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 10-01-2013, 05:26 PM
Dubble Dubble is offline
Dubble is on a distinguished road
Default Bumpy Ride
My 2013 Ram 1500 ST ( base model doesn't even have a CD player ) has a pretty bumpy ride. I went from driving a dodge journey to a truck so I knew the ride would be a bit different. The truck has quite a bit of roll when I am turning corners and I feel every crack and little knick in the pavement. Would aftermarket shocks+shock absorbers help and any suggestions on which ones? My tires are wrangler SR-A and tire pressure is 40lbs.
Old 10-04-2013, 12:21 AM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
i noticed a big change even going from an '11 ram to my '13...felt the bumps a lot more in the '13 on stock. i've have tho noticed quite a difference for the better in the front end since adding the Bilstein 5100s. I did add a level at the same time but i'm sure even running stock height there'd be a significant improvement
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 10-23-2013, 07:41 AM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
Exactly what this man says. Get the Bilsteins.
Simon
Old 11-19-2013, 02:46 PM
medic18d medic18d is offline
Vehicle: 2013 express cc 5.7 hemi
Trim Level: blacktop edition
medic18d is on a distinguished road
i think you were used to a smoother ride with the journey. i would not get bilsteins for comfort . my pic for comfort is monroe sensitrac
helped me with my old beat up ranger .
Old 11-23-2013, 10:47 AM
h2oman's Avatar
h2oman h2oman is online now
Trim Level: Express 4X4
Rep:308
Bilsteins make for a very plush ride.
333Half the beast
I used to be
Old 03-02-2014, 11:17 AM
glcarter's Avatar
glcarter glcarter is offline
Vehicle: 2011 Ram 2500
Rep:49
glcarter is on a distinguished road
All I can say is it is a truck. If you want a plush ride buy a Cadillac, or put some weight in the back like a truck is designed for.
You cannot expect something like a truck that is designed to work to ride like a Journey that is designed to run kids around and get groceries. You can make changes the add expense and comfort but, some will reduce the usefulness of a truck.
Drive a late 60's truck then get in yours and it will feel like you just stepped into a Caddy.
Just picking brains, mine's worn out!
Old 03-21-2014, 12:37 PM
jharrram13's Avatar
jharrram13 jharrram13 is offline
Vehicle: 2013 dodge ram
Trim Level: express
Rep:25
jharrram13 is on a distinguished road
I know what your saying on the ride. And just because its a pickup doesn't mean it has to ride like crap. Seems like it differs from truck to truck. Fords are horrible!!! I had a chevy dually I drove for work and it road like a Cadillac even with a 20000+ lb trailer behind it and then they switched me out for a ford and its a darn lumberwagon. So to me my ram rides like a Cadillac lol
Old 03-21-2014, 04:16 PM
BlkXpress25's Avatar
BlkXpress25 BlkXpress25 is offline
Vehicle: 2013 Ram Black Express
Rep:28
BlkXpress25 is on a distinguished road
My express rode beautifully til I lowered it... but that was to be expected
Old 07-30-2014, 03:46 PM
Bill55AZ Bill55AZ is offline
Color: Steel
Bill55AZ is on a distinguished road
For town driving, I run lower tire pressure. 36 psi makes a difference when driving on poorly maintained roads. When making the twice a year trip to Phoenix and back, I put the tires back up to normal pressure.
Retired USN, Vietnam, AO, Parkinson's stage 3, married, 2 kids, 7 grandkids,
Solar cooking nut
Old 08-01-2014, 12:18 AM
Hornet Hornet is offline
Vehicle: 2013 RCSB Ram
Rep:470
You have no rear swaybar on a ST,adding even the factory bar will make a differance on body roll.
I'm taking it the trucks a regular cab shortbox,other then weight in the rear,there's not much you can do for the ride if you're using the stock springs.
Shortbox trucks have notoriously rough and choppy ride,just the nature of a short wheelbase vehicle
Aftermarket lowering springs are usually progressive and will sometimes give you a better ride.
What part of Alberta are you in.
I have a regular cab shortbox ST with the aftermarket Hellwig swaybar and Mcgaughy's lowering springs,with 285/60/17's on the rear and 275/60/17's on the front,and it still rides like a D8 Cat.
Just realized this is damn near a year old,wonder if he still has the truck
rough ride, shocks, shocks springs
