1996 Dodge Ram 1500HD Custom Build Thread - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-01-2013, 07:13 PM
beginningjockey's Avatar
beginningjockey beginningjockey is offline
Vehicle: 1996 Dodge Ram F1500HD Custom
Trim Level: SLT Laramie Custom
Rep:22
beginningjockey is on a distinguished road
Default 1996 Dodge Ram 1500HD Custom Build Thread
well I was pleased that there was a section dedicated to custom builds lol... most forums don't have that.
So to start it off, the truck, as it came from the factory, was a 1996 Dodge Ram 1500 SLT Laramie (loaded!) 4x4 longbox extended cab, with a 46RE automatic (4spd overdrive automatic), NV231HD transfer case, it did not have the tow package but did have the heavy duty rear bumper as found on the tow package equipped trucks, and here's what the build sheet shows:
Code:
According to our records, your vehicle was equipped from the factory
with the following:
Sales Code Description
*P1 Premium Cloth 40/20/40 Bench Seat
-D5
ADAP Light Group
AJKP Convenience Group
AJPP Power Convenience Group
APAS Monotone Paint
ASPP SLT Decor Group
BAUS 117 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS 11x2 Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CGTS Driver Air Bag Only
CHEP Deluxe Headliner
CKEP Front Seat Area Carpet
CLAP Front Floor Mats
CSPS Passenger Assist Handle
CSRP Passenger Assist Handles
CUDP Mini Overhead Console
DGB All 4-Speed Automatic Transmissions
DGTS 4-Spd. Automatic 46RE Transmission
DHAS Lock-Up Torque Converter
DHKS Shift-on-the-Fly,231HD Transfer Case
DJCS 195MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
EAAC All Engines
EML 5.9L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GFD Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNMP Passenger Side Sun Visor w/Mirror
GPUS Manual 6 x 9 Black Mirrors
GVAC All Vehicles W/O Power Mirrors
HAAP Air Conditioning
HGAP Hood Insulation
HGBS Dash Liner Insulation
JAYP Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBP Dual Note Electric Horns
JJJP 12V Auxiliary Power Outlet
JPAP Power Windows
JPBP Power Locks
LAAP Ignition Time Delay Lamp
LBAP Map/Courtesy Lamp
LBCP Glove Box Lamp
LDAP Underhood Lamp
LMAS Halogen Headlamps
LPEP Cargo Lamp
MBFP Bright Rear Bumper
MCTP Bright Front Bumper
MDAP Front License Plate Bracket
MFDS Bright Grille
MHAS Black Windshield Moldings
MPBP Black Tailgate Applique
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCP Front Bumper Sight Shields
NAA Federal Emissions
NBKS EVAP Control System
NFVS 35 Gallon Fuel Tank
NHMP Speed Control
PW7A Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RASP AM/FM Cassette Radio
RCDP 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TYKP 245/50R20 BSW All Season Tires
TZAP Goodyear Brand Tires
WLBS Steel Spare Wheel
WNDP 16X7.0 Cast Aluminum Wheels
XBSS Pickup Box
XCMS Vendor Painted Cargo Box
YAAS Build To U.S. Mkt. Specifications
Now this truck has always had a clean title, but somewhere along the lines before we got it, probably when it was brand new, it had the airbag blown, ALL of the glass replaced, the dash replaced, all of the front panels, bumper parts, horn, etc. replaced, and there's evidence of stuff on the side of the truck (drivers side) too on the doors, so all I can say is it was in an accident at some point in it's life, frame is straight and all the repairs were done competently enough that most people looking at it don't notice those small details...
My dad bought it back in 2006 (yes it's his truck, but I use it alot and do all the work on it lol) to replace our 1982 GMC Sierra that barely could move under ITS own WEIGHT lol... $6750, and it only had 115,000 miles on it. Not a bad deal (at the time). in it's day it was ALMOST the fanciest Dodge you could buy.
When we got it, we did just the normal stock things people do, only change we made was to put on 265/75/R16 8 ply mud tires. BTW, sorta jumping ahead, but the spare was the factory spare, never been used until last year, never had to put ANY air in it EVER.)
We also put mats oon the floor, and put in a new 120AMP high-output alternator, new 750CCA battery, new battery cables, and I redid the trailer wiring on the truck end and installed a trailer brake controller. I also did most of the regular maintenance,
and did what I call "stock" upgrades, i.e. brass contact dizzy cap and rotor, 8MM HD spark plug wires, platinum plugs, I installed rear shocks with big coil springs on them to assist with trailer towing (and by the way, them Monroe shocks work AWESOME, on my third set and never will I move unless I find something with more features and better reviews).
Thus far was what I did to it, it remained bone stock otherwise.
Then last year the customization started in August, with what was SUPPOSED to be a $200 repair fixing the plenum gasket...
Well I'm gonna quite there as I need to go out for chores now, and I'll post this part, knowing how my computer likes to erase everything I was working on lol, I won't forget
2016 Ram 3500HD, DRW, CCLB, 6.7 Cummins, the notorious 68RFE, 4WD, etc, etc.
2005 Nissan 350z
