Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 10-01-2013, 07:49 PM
weldguy weldguy is offline
Vehicle: '09 Dodge Ram TRX4
Trim Level: TRX4
Rep:13
weldguy is on a distinguished road
Default Rear Whine...New Question
My '09 Ram has a slight whine from the rear end ONLY between 47 and 52 mph. As a side note, I recently heard the exact same whine in a brand new Charger.
Back in the day, it would be referred to as a "harmonic" and manufacturers would often tune it out with exterior weights. I thought I might try to control it by adding a sound dampening material to the underside of the bed and cab. I also thought about shooting some of it on the stamped steel dif cover, but don't know if that would allow heat to build up in the rear end. Could also try a cast aluminum cover, but that would be an expensive experiment.
What say you experts???
Old 10-05-2013, 08:21 AM
3nitros 3nitros is offline
Vehicle: 2010 dodge ram slt
3nitros is on a distinguished road
sounds like you have bearing going in the rear end
Old 10-05-2013, 09:18 AM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
mine is doing that to, and it got louder
but their rebuilting the rear end so it should go away
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 10-06-2013, 07:14 PM
Trim Level: TRX4
Rep:13
Default Noise
If it's a bearing, why would a new Charger... 148 miles... make the exact sound at the exact same speed?
An additional point, the whine only occurs at speed or acceleration, not when decelerating. It stops when I lift off the throttle.
Old 10-12-2013, 09:31 PM
Kaiser Kaiser is offline
Vehicle: 2011 Ram 1500
Kaiser is on a distinguished road
Sounds like a pinion bearing going bad. OR the pinion nut has started to back off.
