Replaced Wheel bearing Hub and Broke again immediately? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-01-2013, 10:58 PM
Justpeachyy Justpeachyy is offline
Vehicle: 1994 Dodge Ram 1500 4X4
Justpeachyy is on a distinguished road
Default Replaced Wheel bearing Hub and Broke again immediately?
There is no play in the wheel when jacked up, is this good enough to rule out ball joints?
Old 10-02-2013, 12:17 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Either it wasn't put on straight or you have a bent knuckle. I'm thinking it's not the ball joints.
Old 10-03-2013, 02:46 PM
dabranco dabranco is offline
Vehicle: 1996 dodge ram
Color: red
dabranco is on a distinguished road
UP and down is used to check for ball joints and left to right is for the tie rods. I would use a pry bar at the 6 oclock position on the wheel/tire assembly and lift gently, and record the play there should be little to know play then with both hands at 3 and 9 oclock position wiggle the tire to check for play there. The tie rod and ball joint is more effective with a second person to help as you or they may be able to see something other then the tie rods or ball joints being bad.
Old 10-05-2013, 11:14 PM
83camocharger's Avatar
83camocharger 83camocharger is offline
Vehicle: 1996 Dodge Ram
83camocharger is on a distinguished road
i got a 96 ram 4x4 and when the first front left wheel bearing went out, i changed it with a masterpro, then a month later it started grinding....changed it and upgraded to a precision wheel bearing and its been 2 months and its out again. I dont know a fix to it but were in the same boat.
