Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
ZDOG
Old 10-02-2013, 08:53 AM
Hemiproud Hemiproud is offline
Vehicle: 2010 Ram Crew Cab Hemi
Color: Tan
Rep:23
Hemiproud is on a distinguished road
Default Sluggish/ Bad MPG
Here lately my 2010 Hemi has been sluggish at highway speeds ( 60 mph and up) and the throttle response is horrible. I drive roughly 80 miles a day, too and from work and 70 of that is on the highway and I cant seem to break 15.9 mpg. It currently has 43K on the clock with K&N Drop-in, DSP 91 tune (running 93), and flowmaster exhaust. I have not changed the plugs yet, could that be some of the issue?
Old 10-02-2013, 09:01 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
I'd say most definitely. Battery could be going as well. 3 years going on 4 if OE.
Old 10-02-2013, 09:35 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Plugs would definitely be a concern. I'd get those changed out. Also, have you run any cleaner, like Seafoam, through the tank? That might help clean out some of the garbage as well.
Old 10-02-2013, 09:37 AM
Color: Tan
Rep:23
I kind of figured that the plugs needed to be changed. I just wasn't sure being that from what I have read the majority said that it was a waste of time and money to change them before 60K. I just hope this helps because I am definitely missing the pep that it had when I got it. Thanks for the help.
Old 10-02-2013, 09:44 AM
Color: Tan
Rep:23
I have heard of Seafoam but never used it. Does it actually work?
Old 10-02-2013, 09:58 AM
picker picker is offline
Vehicle: 2005 ram
Trim Level: st
Color: mineral grey
Rep:9
picker is an unknown quantity at this point
We run our trucks 100K plus before plug swap, Try staying away from discount fuel stations, My son-in-law drives a fuel tanker BELIEVE it when I tell you there is some terrible fuel going to these off brand stations. Try Sunoco, Mobil, Chevron, any with fuel additives advertised. Few tanks of good fuel might surprise you. If you do pull a plug and it's brown instead of light grey you have a "gummed" up fuel system. Your injectors are "dribbling". Sort of like a plugged spray paint nozzle. Picker.
Old 10-02-2013, 11:25 AM
Color: Tan
Rep:23
I get fuel from Valero, Texaco and Buc-ees gas stations. I tried Chevron but I got a lot of knock/pinging at WOT so I quit buying gas from there. I believe you on the bad fuel because my wife used my truck for a few days and put some SAC-N-PAC BS gas in it and it sounded like there was a pinball tournament under my hood every time it shifted @ WOT for like 4 days. I will pull a couple plugs and see what they look like.
Old 10-02-2013, 05:42 PM
Rep:2968
IMHO, and several others here, I think it does. Cleans the injectors and if you run it through a vacuum hose &/or your TB, it'll clean up the intake.
Old 10-03-2013, 07:43 AM
Color: Tan
Rep:23
I put can of it in my truck last night when I filled up and I am now a believer. I could tell a difference on my way to work this morning. It seemed to have a smoother idle and better acceleration. As far as MPG I'm not sure yet being that my foot was just a little heavy this morning. Thanks again for the help.
Old 10-03-2013, 10:18 AM
Rep:2968
Voonderbar! Well add your name to the list of believers.
