Old 10-02-2013, 03:55 PM
neuman22 neuman22 is offline
Vehicle: 2009 Ram 1500 Crew 4x4
Trim Level: Lone Star
Color: Blue
neuman22 is on a distinguished road
Default Overhead dome light switch not working
Has anyone had problems with the overhead dome light not working? When I click the light to turn it on it won't work, but when I turn on all the lights with the dimmer switch they'll come on and will also cut off if I click the light while I have all the interior lights turned on using the dimmer switch. Freaking weird, a fuse, or bad relay maybe?
Old 10-03-2013, 01:10 AM
RogerRamJet's Avatar
Vehicle: 2005 RAM 1500
Trim Level: LoneStar QC
Rep:2933
What kind of lights do you have in it? LED's? You may have an issue with there not being enough load for it to come on. In which case you would have to solder a resistor on to the bulb.
Old 10-03-2013, 06:57 PM
Color: Blue
Nope, no LEDs, it's all factory. I haven't changed anything out.
Old 10-03-2013, 10:29 PM
Rep:2933
Ok, maybe a bad bulb? I was having an issue like yours, except it was with my map lights. Different generation Ram, so I'm guessing a different issue. I fixed mine with a resistor. Now I'm stumped. I reckon it's time to break out the volt meter and start testing and troubleshooting. Wish I could've been more help.
Old 10-10-2013, 12:16 PM
Color: Blue
I'd do that, but like I mentioned in my first post the light works when I turn on all the interior lights via the dimmer switch next to the headlight switch. They just won't work individually when I try to turn them on. I'm stumped
Old 10-10-2013, 11:07 PM
Rep:2933
Mine did the same. Would work when the door was opened or if I turned them on with the switch, just not individually. With the resistors, they work great now, both with the door/switch and individually.
Old 10-11-2013, 08:59 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Sounds like a bad switch on the light.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-11-2013, 09:46 AM
Grubrunner's Avatar
Rep:3883
Yes, if they work one method and not the other than you can rule out the bulb.
The switch is a good start.
Grub out!
Old 10-14-2013, 10:59 AM
Color: Blue
So another thing I noticed when my wife pulled down the visor to use the mirror yesterday is the vanity lights are not working either. Anyone know if these are all on the same switch, fuse, or relay?
Old 10-14-2013, 12:15 PM
Rep:2933
They probably are on the same fuse (interior lighting). Since you do have light, I'm guessing it's not the fuse, more likely a burnt out bulb or faulty switch.
