Old 10-02-2013, 09:15 PM
Jhouse's Avatar
Jhouse Jhouse is offline
Vehicle: 2014 ram
Color: blue streak pearl
Rep:163
Jhouse has a spectacular aura aboutJhouse has a spectacular aura about
Default Whistling/squealing sound
Ive been hearing this whistling or squealing sound since about the time i installed my tb. Its only at low rpm maybe up to 2k then it goes away. Is it from the tb or? Any ideas?
K&n cai, bt catch can,moes 87mm throttle body,flowmaster super 44,20% tint front 15% rear,egr vent guards, black weatherguard toolbox, debadged,tinted tails,retroshop hid's 6000k in fogs and lows, custom mopar badges
Old 10-02-2013, 10:08 PM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
Did you put a TB spacer on also? That would be the answer if you put on a spacer
Supercharged, cammed, other things too!
Old 10-03-2013, 05:56 AM
Jhouse's Avatar
Vehicle: 2014 ram
Rep:163
No no spacer just the moes 87mm tb
Old 10-03-2013, 01:47 PM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
Did everything link back up correctly? IT could just be a leak somewhere along the air intake that's loose. Maybe something you just didn't tighten all the way or that slipped once it was put back on
Old 10-13-2013, 10:22 AM
HemiExpress2013 HemiExpress2013 is offline
Vehicle: 2013 Ram 1500 Express
HemiExpress2013 is on a distinguished road
I thought I'd chime in on this. I also have the same noise from installing Moes 87MM TB. It's been in for 5 months I guess. No, problems from it. I thought it was from the lip at the intake plenum(it's 83mm), TB being 87mm tapering to 84mm. Took the TB off and ported the Intake plenum to 84mm. Same noise. TB really needs to be polished.
Old 10-13-2013, 10:26 AM
Jhouse's Avatar
Vehicle: 2014 ram
Rep:163
Ive taken everything off and put it back on again still there. I wonder what the cost of getting it polished would be? And any pros of it?
Old 10-14-2013, 09:09 AM
Polishing should net .8-1 hp gain, give or take a couple of points. I never put the stock TB on to see if the whistle went away. The 87mm was the second mod I did at the time, BT catch can was first. The whistle definitely started with the 87mm TB install. Polishing would also help with less air turbulence, the whole Venturi effect is kinda mute at the TB because of the large volume air chamber of the Intake manifold and no mixing of gas like carbureted vehicles. Air velocity slows dramatically just past the tail of the venturi. The intake runners are where the venturi is most important but turbulance slows air speed and that is never good, as well as too big of a TB. The ported 87mm works great it just has made my trucks acceleration laggy past 90+ compared to the stock 80mm. I just want to try different combos. I'm gonna try a SharaDon Performance 84mm TB at some point. Then I'll have the 3 TB to use and compare. When I do a cam swap, I'll want the 84mm for sure.
