30 psi compression in cyl 8. 2000 ram 5.9 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-03-2013, 12:47 AM
tedf151 tedf151 is offline
Vehicle: 2000 dodge ram
Trim Level: sport
tedf151 is on a distinguished road
Thumbs down 30 psi compression in cyl 8. 2000 ram 5.9
hey guys, i just got the crappy results from my at home compression test. im getting 150 psi out of every cylinder except for number 8...which read 30 psi. i hear stories of 100 psi and having to to lifters valves or seats ext.... but i feel like with the 30 psi reading im getting, that the issue is way more severe than what other people are having. i am also loosing coolant also. im also not burning oil either. so that may rule out piston ring, but the coolant loss could point to a head gasket failure???? let me know what you guys think.
Old 10-03-2013, 01:06 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Check the oil for coolant, but if you're losing it and don't have any puddles, more than likely it a head gasket. If you're not losing/burning oil, could very well be a valve.
Old 10-03-2013, 01:10 AM
Trim Level: sport
ok thanks. that helps alot. anyone else with answers?? just trying to take everything into consideration
Old 10-03-2013, 03:23 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Always possible something whacky has happened, but RamJet covered the most likely culprits.
Old 10-11-2013, 11:01 PM
spun360 spun360 is offline
Vehicle: 96 ram 1500 367ho
spun360 is on a distinguished road
its easy to pump up the cooling system with the rental tools from an auto parts house. this could rule out one of your problems. then just replace the junk stock heads with iron EQs to fix you valve issues!
misfire, valve, valvetrain
