Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 10-02-2013, 11:48 PM
mnguy55 mnguy55 is offline
Vehicle: 1970 Charger R/T
Rep:16
mnguy55 is on a distinguished road
Default Anti spin
Several years ago (like 10) there was an issue with "clips" in the antispin rear ends falling out and getting ground up and ruining the gears. I'm looking at ordering a 2014 and one option I'm considering is antispin. Does anyone know if this issue ever got solved or does it still happen in the 2009+ trucks
Old 10-03-2013, 12:51 PM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is offline
The Sound of Eight Hooves
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:747
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
Starting in the 2013's Chrysler has used a TorSen style LSD rather than a clutch pack style LSD. This eliminates the problems you are asking about, however it makes it a lot more expensive and difficult to change your diff gearing if you ever want to do that. The 2009-2012 LSDs use clutch packs.
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 10-03-2013, 02:36 PM
Rusty289's Avatar
Rusty289 Rusty289 is offline
Vehicle: 2014 Ram 1500 Crew Cab
Rep:117
Rusty289 will become famous soon enoughRusty289 will become famous soon enough
I've never had an issue with my 2009, I'm not hard on it though and only have a little over 50,000 miles on it.
If ya can't Dodge it, Ram it!!!
Old 10-03-2013, 05:06 PM
Rep:16
In the 2014 owners manual it says you need to add friction modifier on a 1500 antispin but not for the 2500/3500. The only time I have seen that you need a friction modifier is with a clutch type LSD. My Chevy has a factory locker (not a clutch type) and doesn't need modifier. If the 1500 had a TorSen would it still need a modifier?
Old 10-03-2013, 10:16 PM
Rep:747
I noticed that too but to be honest I don't know the answer.
Thunderhorse:
Colt:
Old 10-04-2013, 04:14 PM
ramit355's Avatar
ramit355 ramit355 is offline
Vehicle: 2014 1500 4x4 CC Laramie 392
Trim Level: Laramie Crew Cab
Rep:28
ramit355 is on a distinguished road
i can say the LSD it totally different from 2003 Laramie over the 2011 and 2014 when driving and breaking rear wheels loose!!! The 2003 never spun at first near like the 11 and 14 does.
Old 10-05-2013, 02:13 PM
Rep:16
I was at the local Ram dealer today and I asked the parts guy to look up a 2014 1500 rear end. Looking at the parts diagram it showed a clutch plate pack? That does't seem to line up with people with anit spin saying they jack it up and spin one wheel and the other spins the opposite direction like an open diff. I wonder if the diagram is wrong?
Old 10-06-2013, 09:04 AM
ramit355's Avatar
Rep:28
Sounds like a clutch Diff to me. Mine does spind very much at all ,but it does if you nail it hard. But if you try a break Rev it will not break loose.
