Old 10-01-2013, 02:51 AM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
Default Don't do this at home
So the neighbor and I are working together on our adjoining logging roads for winter fire wood. I ran down the logging road and at the first turn around, on the far end of the left turn radius in 4L I misjudged the bank, goosed it to hard and slammed the right front up against the bank (flush). I shook it off, proceeded back up the logging road and finished dragging the logs up to the top.
The next day I got up, had the morning coffee and the right front was about half flat. I fired up the compressor and added air, put the water hose to it and watched it slow leak due to dirt deep in the rim for about 4". I took it down to my buddy that has a full service garage and we took tire tools out and removed the debris, once we added air we checked for leaks with a hose, this sealed it up. It could have been real bad if I had not hit flush.
LESSON for me:
The 4 low turning arc should not have "hurry" in the mix. Thought I'd share my blunder. R...
Old 10-01-2013, 08:12 AM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
Ouch.. Ya 4Low is for sure not for speeding around with. Glad there was no serious damage and that you got it all fixed easily.
IG:@briley59
Old 10-01-2013, 05:17 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:379
Glad you're ok.
Bilstein 5100's at 2.8. Fox 2.0 rears. MBC Razors with Goodyear Duratracs. Airlift 1000 air bags. Mopar Tow mirrors. K&N air filter. Mopar rock deflector. More AR's than you can shake an AK at.
Old 10-01-2013, 08:29 PM
dvarn's Avatar
dvarn dvarn is offline
Vehicle: 2009 Dodge Ram 4x4 QC
Color: Stone White
Rep:187
dvarn has a spectacular aura aboutdvarn has a spectacular aura about
Lesson learned and passed on. Glad it was a simple fix for you
Old 10-02-2013, 03:07 AM
Rep:177
Thanks all. It had just started a light rain and I was trying to get my 36 year old neighbor out of the rain (I pushed beyond the laws of physics and truck capabilities). R...
Old 10-04-2013, 09:26 AM
Spike Spike is offline
Vehicle: 2013 RAM Big Horn 4x4
Rep:58
Spike will become famous soon enough
Good write up...that moster torque of the diesel can get a fella in trouble in 4lo,
Are you running the stock tires?
My buddy has a Ram almost identical to mine and he is still running the stock tires. They don't "pooch" out from the wheel at all and he has scraped his wheels a time or two. They are pretty boogered up now. My 305's pooch out from the wheel a bit and I know that has saved them more than once from being damaged.
2.5" Lift, 305 R20's, Winch, Softtoper,
K&N, ZJ in tow, German Shepherd co-pilot
Old 10-04-2013, 10:14 PM
Rep:177
I hate to say it but I wouldn't run stockers. I see our HEMI guys on this board with the stockers and I'd be afraid to get off the pavement with them. I tend to get new sets for personal rides and let my tire guy (local) give me a value number to knock off my bill. You bring up a good point though. The truck in the mishap is my old Ram 4x4 360 farm truck and the tires do not extend out as you describe. My diesel does with a level on 285/75/16's, and one I just picked up has 17/11.5/33's in which case the tire rubber would have prevented the rim from banging the bank (at normal PSI). 305's there's some money! R...
