Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 10-03-2013, 05:38 PM
MattGT MattGT is offline
Vehicle: 2012 Dodge ram
MattGT is on a distinguished road
Arrow 2012 ram zex kit install HELP
Looking to install a zex kit on my 2012 ram 5.7 SCSB
Is there anyone on this forum that has successfully installed one
On there truck , where would I tap for fuel ,what is the stock fuel
Pressure and what shot is safe I heard a 100 is good am only gonna be using
This kit for 2 passes at the track then removing
My mods are kn63 CAI , Diablo sport i1000 dcx w/ custom 91 hemi fever tune
Muffler delete,
This info would be much appreciated
Old 10-03-2013, 07:55 PM
jerseymike's Avatar
jerseymike jerseymike is offline
Vehicle: 2013
Rep:116
jerseymike will become famous soon enoughjerseymike will become famous soon enough
Check in the nitrous section.
http://www.ramforumz.com/forumdisplay.php?f=136
Old 10-03-2013, 09:29 PM
I push the skinny pedal
Rep:3277
Firstly, when running nitrous, you don't want to run you 91 tune. Run 91 or 93 fuel, but run the 87 tune, it doesn't advance the spark timing, or you can run the 89 tune and pull 2 degrees for a 100 shot, and you can run up to a 125 shot for short durations, just make sure you pull 4 degrees of timing from the 87 tune.
A set of 1 step colder plugs is highly recommended after a 75 shot.
If you have a Zex kit for a truck then it should come with a piece that will go between your fuel rail and the fuel supply line, this has a 1/8" npt thread in it to screw the -4an fitting into, this then goes to the -4an hose to the fuel in on the control box.
stock fuel pressure is 55-58psi.
Kurtis
Old 10-04-2013, 01:12 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
exactly this ^^^^
Thanks
Jeremiah
Old 10-04-2013, 08:41 AM
Do you have any guide to installing ?...
zex nos fuel tune
