Old 10-04-2013, 12:26 PM
Friz Friz is offline
Vehicle: 83 Prospector
Trim Level: Prospector
Color: tan
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
Friz is on a distinguished road
Default 83 3/4 ton Prospector - is it worth it?
Hello Dodge lovers. I also posted this in the Newbie forum, maybe I'll get better response in here...
I am seriously considering purchasing this truck. I looked at it and drove it yesterday, it is straight with original (I think) paint, it runs strong clutch is good and everything works mechanically and electrically. I didn't see any oil or transmission fluid leaks.
I don't plan to modify, I only want it is a 120 mile once per month commute and to be used as a work truck. I also have a 5th wheel camper that I would tow once per year at the most.
I'm going to look at it again today and would like some tips on what to look for.
What do you think this truck is actually worth?
It is a craigslist item. This is the post and the photos, the photos are of the actual truck.
This truck was recently inherited. It is in good shape it has a 318 and a 4 speed granny transmission. This truck is smogged and registered. Its registered until june 2014. I am not a dodge guy I'm a chevy guy, with that being said ill sell for 2450.00 obo or trade for equally valuable chevy or gmc extended cab pickup. 1/2 ton 3/4 ton 350 or 454 doesn't matter. However truck needs to be currently smogged and registered.
This truck has a 5th wheel in the bed it has a fuel tank in the bed and a tool box in the bed. The 5th wheel is easily removable. The truck has got in the last month since i inherited it has got a new starter, fuel filter, fuel pump, spark plugs, a motor mount, rebuilt carburetor, cooling system flush, a radiator. These older trucks are easy to work on. This one has been taken care of. The battery in it is a deep cycle starting battery it starts every time. Thanks for looking and please email me pics of what you want to trade thanks.
Old 10-04-2013, 01:02 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I posted this in your newbie checkin post, however I will post it here as well.
That truck has a lot of potential, I have been wanting an older 3/4 ton dodge for sometime, I would not be comfortable paying more than 2k for it though, this is just me. However when I find my older dodge beauty the 4 speed tranny is to be immediately rebuilt, the rear end is to be rebuilt, the engine is to be rebuilt or possibly even replaced, and then the suspension is to be replaced with modern suspension, slam it to the ground and then the interior is to be completely over hauled, and the body to be repaired/painted.
Of coarse this would be a daily driver for me and I would be building it for reliability for a long time to come and it would be near show quality.
for what you are wanting to do to with the truck I would still not be comfortable paying more than 2k for it, and you are going to want to make sure you do a complete tune up on the engine, probably replace the rubber parts of the break lines if there are any, and make sure to flush the cooling system, and replace all other fluids with new fluids, you will want to go through it and make sure it is safe to drive before you buy it, check to make sure there are no break lines rusting/dry rotting anywhere, and make sure the tires are sufficient to drive on.
If I was going to buy this truck for what you are explaining you need it for, try to pick it up as close to 2k as you can or less, and plan on investing about $700-$1000 in a very thorough tune up
Hope this helps
thanks
Jeremiah
Old 10-04-2013, 01:07 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
just noticed he said the radiator has recently been flushed so probable do not have to worry about that, I would still make sure to do things such as change the oil, change the rear end fluid, tranny fluid, probably would not be a bad idea to run some fuel treatment system through the first couple tanks of fuel to make sure the fuel lines are nice and clean, replace rusted parts of the steal break lines, and the rubber parts of the break system if there are any if they are dry rotted this is a common thing on older vehicles, new spark plugs, probably time to change the distributor and plug wires as well.
again hope this info helps, and the truck may or may not need all of that, however when I buy an older vehicle regardless of if it needs it or not these are some of the very fist things I do before I even go get it inspected just to be on the safe side.
It may also be wise to check the clutch for slippage on a short test drive, if it is starting to slip chances are it has been a while since its been replaced if ever and would not be a bad idea to replace it with a nice new heavy duty clutch especially if you plan on towing with the truck, depending on how much weight you plan on towing might not be a bad idea to invest in some helper springs or new leaf springs in the rear either. Old leaf springs seam to sag when under load and this can be a nightmare when towing and a lot of times not safe either.
Old 10-04-2013, 06:04 PM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
Jeremiah, you left out the part about painting it black. R...
Old 10-04-2013, 06:06 PM
Asur Asur is offline
Vehicle: .
Rep:4371
That thing is still sweet
Old 10-04-2013, 08:49 PM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
That puppy looks like it has led a laborious life. Price better reflect how much life has been used up due to a hard life.
Old 10-04-2013, 09:22 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Hate to say it, but 140 hp? That is seriously underpowered, I think. With a fifth wheel, you'll need a tailwind. Nothing wrong with a 318, you could actually build one and make decent power, but, I'd save up some more money and perhaps a Cummins or even a hemi. Friend of mine bought a 4x4 extra cab 2001 2500 with a 24 valve Cummins for $4995 , private party sale. To me, even the Cummins felt kinda doggie for towing a fifth wheel. I had a 3l Ford Ranger with 140 hp, it wouldn't tow squat.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 10-04-2013, 09:37 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
On an older truck it would have to be a flat black IMO
Old 10-04-2013, 10:10 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Yes I likey! Flat black and slammed to the ground. That 83 would be too badass!
Old 10-05-2013, 12:19 AM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I agree with this ^^^^ flat black is not only one of the best looking colors on older vehicles and just so happens to be not be a very expensive paint too
