shifting issues - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 10-04-2013, 04:14 PM
craig4219 craig4219 is offline
Vehicle: 2012 RAM 1500
craig4219 is on a distinguished road
Default shifting issues
on my 2012 ram 1500 sport i can't shift into neutral, park or reverse from drive. i got the shifter into park to release my key but the display on the dash still says reverse. i disconnected the battery to try and reset anything but nothing happened. if you have any insight please help me out.
thanks
Old 10-07-2013, 08:01 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:501
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
Do you have the display where you see the PRND all the time, and they change color to indicate the current gear position? Is the "R" red, but the remaining letters (P, N, and D) are all GREEN (not white)? If so, then you have a Trans Range Sensor (TRS) fault (P0706), which means that the PCM is getting a bad (invalid) signal from the TRS (inside the trans). Your PRND letters should normally be WHITE when they are "off." For example, in Park the "P" should be green, but R, N, and D should all be white. In Reverse, "R" should be red but the others should be white.
Whenever you have an invalid TRS reading, the display illuminates "all" the positions (turns them all to their "on" color). Since R is red and the others are green when "on," it looks like the trans is in Reverse. But actually, it is indicating an error (all "on") condition.
The TRS has 5 wires (each connected to a pin on the sensor, which runs against a code plate in the trans). Usually, P0706 indicates a problem with one of those wires (bad connection, broken wire, etc.). Do you get the "all" indication in every PRND position? Is there any position that is OK? Does the trans still actually operate OK? (it should). If you'll tell me which position(s) (if any) are OK, maybe we can figure out which pin(s) / wire(s) are bad.
Old 10-07-2013, 09:07 AM
mgh's Avatar
mgh mgh is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
This could be a shift cable adjustment issue. I have worked on a '12 and had the same issue.
