Old 10-04-2013, 06:30 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Default My Daughter's '93 Mustang
So I've had my daughter's car outside this summer (She's 7) I uncovered it and washed it.
Went to start it and it wouldn't start. Did a KOEO (Key off engine off) scan with my old scanner, wiggle test, etc...
Dead fuel pump. Go out and buy a new fuel pump. Drop the tank...eeew. Order a new tank etc...
Put new grommets in, new pump, sending unit...undercoat the body above the tank, and put some new fuel in it.
Cranks, won't start.
This goes on for about an hour and I get somewhat discouraged and walk away.
Bright and early this morning try it...cranks, won't start. Get some clear fuel line, route it to the TB, turn the key on, jump the solenoid, fires up but runs like doo doo. Take away the clear auxiliary fuel line and try it on its own. Cranks, no start. Fuel line and fuel again. Runs like doo doo.
Scan it again and everything is working. Pull the plugs (2.3 has 8 plugs) the driver's side is a pita. They all look fine. Clean 'em put 'em back in.
Cranks, no start.
Check the grounds, fuel injectors, rail, and just about every electrical connection imaginable. Clean 'em all, dielectric grease. Coils, fuel injectors, modules, body control module, tank wiring.
Cranks, no start.
Back to the fuel line in the TB. Fires but runs like doo doo. I live in a wooded area and I smell something like it's on fire...leaves, whatever. I take a break and go check it out. Nothing.
Back to the car, fuel line...check. Fuel, check. Crank it and it runs a couple seconds. Smell the fire again...go check it out again. Nothing.
Back to the car. Clear fuel line to the throttle body filled with fuel. Key on, and I jump the solenoid again. Fires with the auxiliary fuel line again, so I let 'er rip. All the fuel in the line and open the throttle body.
The motor is shaking and runs like crap.
All of a sudden it revs up, smooths out, and there's smoke comin out the back like it's a diesel spoolin-up. Let off the throttle body and it's purrin like a kitten.
I go around the back and discover some insulation, acorns, leaves and sticks smokin' under the tail pipe.
So I invested around 6 hours in exterminating and evicting a chipmunk that had made a happy home in the exhaust, and learned that I should cap the tailpipe whenever I put the car outside.
And, I'd suggest that everyone do it.
Old 10-04-2013, 07:02 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
Damn id been getting pissed!!!lol
But that is defiately something different!!
New audio build in progress
Old 10-04-2013, 09:30 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
HAHA! Great story. That stuff will make you turn gray early. Here's one: I work at a marina. Most all boats with outdrives have them removed, serviced and stored for the winter. Rags go into the gimble housing to prevent bird (or chipmunk!) nests from causing problems in the spring. One particular out-driven boat we service developed an over-heating problem when launched. We tried everything. Manifolds, risers, heat-exchanger, belt driven pump, you name it. Still over-heated! So we haul the boat and remove the outdrive with the intention of force-feeding water directly into the water pick-up. It wouldn't take the water! After further inspection, we found that there was a mud-dobbers nest about 3" into the pick-up! Needless to say, we now block off all of them, too!
Old 10-05-2013, 08:14 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
Nice!
It's amazing what you learn through the school of hard knocks.
Exco
Bill
Old 10-05-2013, 08:22 AM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
I read this whole thing waiting for the punchline, something along the lines of this!
I guess you weren't joking!
Old 10-05-2013, 09:36 AM
Rep:4072
Wow, guess I would have been getting aggravated too but mine would have been slightly different, try it, no crank, grab beer, try again lol! Around here, vehicles that sit around outside for a while, the mice like to eat the wiring or make homes in the air box lol. Glad you finally found it though!
Old 10-05-2013, 09:40 AM
HuntCrazy's Avatar
HuntCrazy HuntCrazy is offline
Vehicle: 2002 Dodge Ram
Color: Dark Grey Metalic
Rep:55
HuntCrazy will become famous soon enough
7 year old with a Mustang....SWEET!
Old 10-05-2013, 09:54 AM
Grubrunner's Avatar
Rep:3883
What diameter tips are they?
Grub out!
Old 10-05-2013, 10:22 AM
JWM59's Avatar
JWM59 JWM59 is offline
Vehicle: 2013 Dodg Ram
Rep:148
JWM59 will become famous soon enoughJWM59 will become famous soon enough
My son has A 92 LX with a 5.0. I have a small fortune tide up in that car. I have a 69 Mach with a 428 Q code. I see you are in NJ. You ever take in local shows? Merchantville, Pennsauken etc.
Old 10-05-2013, 11:02 AM
Vehicle: 95
Rep:1776
I'm appalled at the thought that you'd think I wasn't entirely serious from the beginning. But she does have a Jeep Wrangler. Have you ever seen those plastic garden tools for tots? T have them mounted to the hood, shovel, and two other things a rake I think and a hoe. Also put real lights on the roll bar. That would have been a much easier fix as all I have to do is make sure there are no spiders on it, and the spare battery is charged.
I think of it as an investment. It was in darn near perfect condition when she was born so I decided to put it in storage, maintain, and upgrade it. The way I see it, right now it's 20 years old and when she's old enough to drive it it'll be near 40 and she'll know it inside and out. (Not to mention I won't have to buy her a new car)
I dunno what's the waist size on a chipmunk? 2 1/4 inch I think.
I'd have to ask her. Last time she saw me working on it (Oil, flush and fill antifreeze etc...) I got yelled at..."That's MY CAR...you 'sposed to ask daddy"! I did find a nice set of front black tweed seats but I;m having trouble locating the rear for a hatch-back LX.
