Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Towing
Towing 1st Gen Dodge Ram Towing Questions
Old 02-15-2014, 03:13 PM
redwingnc redwingnc is offline
Vehicle: 2011 Dodge Ram
Trim Level: ST Quad Cab 4x2
Color: Gold
redwingnc is on a distinguished road
Default Want to tow a 5th wheel with a 1500 - help!
Towing a trailer is so confusing with all the alphabet soup of GVWR, GAVR, etc! I have a Dodge Ram 1500 ST Quad Cab 4x2, with a 4.7L V8. The truck has a towing package. The Ram specs say I should be able to to tow a max of 7300 lbs. Many RV forums I visited say NO WAY to 5th wheels. Can somebody clear this up for me? In English:-) Thanks!
Old 02-15-2014, 03:25 PM
KidMechanic KidMechanic is offline
Vehicle: 2006 1500 4x4
Color: red
Rep:16
KidMechanic is on a distinguished road
It has to do with how much weight your truck can carry. Fifth-wheel type trailers are usually larger/weigh more than a comparable size tow-trailer. I have seen small fifth-wheel trailers but you lose some interior space to the goose neck, so a similar lightweight tow trailer would be a better choice. I'm no expert on this subject, but have done some research for myself.
Old 02-15-2014, 03:48 PM
Rep:2657
I will not say whether or not you can tow a 5th wheel trailer
This was a discussion that was posted back in 2011
http://www.ramforumz.com/archive/index.php/t-99125.html
Old 02-15-2014, 03:55 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
If I remember correctly...
GVWR/GVAR is the vehicle weight rating (Gross).
As an example it the GVWR/GVAR of your vehicle is 6800 pounds.
That is the most weight the vehicle can carry without exceeding it's weight rating fully loaded.
So say the vehicle weighs 5500. 200 pounds for me and another 425 for my ex-wife, 40 lbs for her purse. 5500+200+425+40=6165. Trailer tongue weight cannot exceed the remaining 635 lbs.
If the tongue weight on the trailer is 500, you still have room for another 135 lbs, or to hide your new girlfriend and her luggage.
(I didn't add fuel weight because that really isn't that important in the example)
Old 02-15-2014, 10:30 PM
Hermes1 Hermes1 is offline
Vehicle: 2015 Big Horn 3500 Cummins TD
Rep:2559
The problem with towing a 5th whelk with a 1/2 ton is the pin weight of the 5th wheel is 20% of the 5th wheel which will typically equal or exceed a half ton payload. There are however small 5th wheels that are towable by half ton's, Escape made in Canada & Scamp are two that come to mind.
Old 02-16-2014, 12:52 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
5th wheelers don't always automatically mean greater weight. Sometimes, it's a choice of having the greater maneuverability afforded by the design, though ultimately, they do extend to heavier weight classes. Still, axle count can nullify part of the tongue weight. A few years ago my dad and I built a 4 axle trailer. Alone it was heavy. Add an 11,000lb boat and it was quite a load, but while it was a gooseneck design, the actual pin weight was surprisingly mild.
