Vararam 'proof'(?)...for skeptics like me - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 10-06-2013, 07:58 AM
GasHole's Avatar
GasHole GasHole is offline
Color: Deep Cherry Crystal
Rep:42
GasHole is on a distinguished road
Default Vararam 'proof'(?)...for skeptics like me
For those considering a new 'cold air' intake for their truck and possibly the Vararam, or those who already have one and are wondering if it is really doing what it is supposed to....
I am probably one of the biggest skeptics when it comes to anything modding, performance, etc.. I almost always take the path less traveled and don't submit to what the 'crowd' is doing. Same thing when I first looked into an intake for my new 2013 Sport. I looked at the reviews, looked at the data available, read all these posts....but who really knew? For all I know, the posts could be written by folks who work for Vararam, right? Well, I went ahead and got one, installed it, and after several miles of the truck 'relearning' the new air input, I actually did notice a harder pull under full throttle. But....was it really pulling in colder air, or was it just my imagination?
Well, here is something I found interesting just recently as the mornings have gotten cooler: when I go out to start my truck in the morning leaving for or returning from work, there is now usually a thin film of moisture (dew) across the entire hood and roof, right? Just like yours, too. As I leave, and eventually get several miles down the road on my trip, that film of dew will eventually always 'burn off' of the entire hood from the heat that the engine directly beneath it is generating.......all except an almost perfectly traced area directly above the semi-square shaped area where the Vararam unit sits! I have noticed this every morning now, and even by the time I arrive at my destination some 35 miles and about 45 minutes later, that same thin film of condensation is almost entirely intact directly above the Vararam. Now, I am no scientist, but common sense would tell you that the area where that moisture has stayed is still that much relatively cooler than the rest of the hood.....meaning to me, that the Vararam really is drawing in truly 'colder' or 'cooler' air to the throttle body...
Just an observation. Pay attention to it, I am sure mine is no different than yours....same design, same truck basically. And it's mute testimony and kind of comforting that it was money well spent on something doing actually what it was supposed to. Let me know your thoughts/observations on this, too.
Old 10-07-2013, 05:07 AM
1stRAM2012's Avatar
1stRAM2012 1stRAM2012 is offline
Vehicle: 2015 Ram 2500
Color: Black on Black on Black
Rep:123
1stRAM2012 will become famous soon enough1stRAM2012 will become famous soon enough
and hats to keep me from thinking you don't work for vararam...
I noticed the same thing after I installed mine
MODS in profile
Old 10-07-2013, 08:21 AM
Zixxer Zixxer is offline
Vehicle: 2013 Ram 1500 Sport
Rep:35
Zixxer is on a distinguished road
Sounds great, but pull the filter cover in a thousand miles and see if you have dirt/girt everywhere. I loved the look, but could never get really solid filter performance...and yes, I checked everything including adding better weather stripping to the base for the filter to seal. Just be sure to check this and service the filter properly.
2" Mopar Lift/285/65/20 BFGs/DB Corsa Exhaust/Mopar flares/Lo Pro Tonneau/Line-X Premium/Ez Down tailgate/Catch-Can/Moe's 87mm TB
Side Molding/345 Emblems/Husky Splash Guards/Honeycomb Grill/25% Tint/Silver Rally Stripes/Crux Rear Camera and VIM
Removed - Air Grabber - filtering is not very good
Old 10-07-2013, 02:08 PM
GasHole's Avatar
Rep:42
Sounds good, will do, thanks.
Old 10-07-2013, 02:09 PM
GasHole's Avatar
Rep:42
Yeah.....no,....my full time job is plenty enough for me already, thanks!
Old 10-07-2013, 09:14 PM
Rep:3347
The reason your hood doesn't completely 'burn off' is because you have a massive void of air between the engine heat and the hood, which acts as insulation, it doesn't necessarily mean you're getting cold air. However, the Vararam does the best of most CAI's that I've seen/worked with of supplying the closest to ambient temperatures. Where it falls flat on its face and is an abject failure as an intake, is its inability to increase your intake flow velocity like a proper short ram intake does.
Old 10-07-2013, 10:15 PM
roo roo is offline
Vehicle: 2013Express,2014 Charger R/T
Rep:44
roo is on a distinguished road
And why would the air be colder than from the fender well of the stock setup?
Old 10-07-2013, 10:29 PM
Rep:3347
Because the vararam has a 'scoop' that goes over the rad and pulls air directly from the front grille in the 4th gen. The 3rd gen is a horrible corrugated tube setup and I wouldn't wish it on my worst enemy's wife. The 4th gen has a much more direct air flow to the filter.
Old 10-08-2013, 02:23 PM
roo roo is offline
Rep:44
It was the 4th Gen I was referring to. Air supplied is ambient on both stock and with the Vararam, not saying though that the Vararam might not give you a small performance boost due to better flow.
Old 10-08-2013, 09:01 PM
Rep:3347
Actually, a short ram intake will always give you better flow, it's a characteristic of their design. Intake air temps aren't the same as the ambient air temp except at highway speeds in the short ram intake design because of heat soak. It's a minimal change, <10 deg, but a change none the less.
The Vararam just gets closer to ambient intake temps because it's a shorter travel distance and you see less heat soak into the intake air pocket compared to most short ram CAIs that use a plastic or aluminum mid-tube. If you want the best mid-tube heat characteristics you want to look at a carbon fiber tube, they don't heat soak and don't pass that heat into the intake air charge.
