Old 10-06-2013, 08:40 AM
beer4all beer4all is offline
Vehicle: 2013
Trim Level: outdoorsman
Color: dark blue
beer4all is on a distinguished road
Default dealer switch tires
on door panel its written p275,60,r20
and i got on lt275,60,17
dont mind the look but difference in size can i get less mileage ou of my truck
Old 10-06-2013, 09:28 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Are you sure about those sized, the Outdoorsman comes with 265-70R-17's (31.61in height) or you can get it with 275-60R-20's (32.99in height), there would be 1.38" difference.
If they are these sizes there would be a 3" difference
275-60-17 =29.99
275-60-20 =32.99
Dealer can adjust the computer for the difference.
The dealer may have ordered the truck with the 20" from the factory, and had a client that wanted them for his truck so they where swapped, you can get your build sheet to check what was on it when it was built, you can also look at the Window sheet and see what you bought, if the window sheet says 20's and you got 17's I would drop back in to see the dealer.
Old 10-06-2013, 09:49 AM
OldJoe OldJoe is offline
Vehicle: 2013 Ram 1500 Quad Cab, 8sp
Trim Level: BigHorn. RamBox
Rep:210
OldJoe has a spectacular aura aboutOldJoe has a spectacular aura aboutOldJoe has a spectacular aura about
I think that everybody should get a build sheet from Chrysler. If I remember correctly there is a higher charge for the 20" tires. If you paid for them, you should've gotten them.
Old 10-06-2013, 09:56 AM
Bhbdvm's Avatar
Bhbdvm Bhbdvm is offline
Vehicle: 2015 Ecodiesel Crew Cab 4x4
Trim Level: Outdoorsman with 6.4
Color: Prairie Pearl
Rep:29
Bhbdvm is on a distinguished road
The Outdoorsman comes stock with 17 inch wheels because they perform better off road which is why many people gravitate toward the Outdoorsman. You can get 20 inch wheels as a $1,400 option on the Outdoorsman. You can also special order 17 inch wheels for the Laramie but the Laramie comes standard with 20 inch wheels. I have considered ordering 17 inch wheels for my Laramie because many say they ride better (more air) and they certainly cost less to replace.
Old 10-06-2013, 10:24 AM
Monster5601 Monster5601 is offline
Vehicle: 13 Laramie 1500, 15 Longhorn
Color: Cherry Red
Rep:470
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
What do you mean by "more air"?
Old 10-06-2013, 12:27 PM
jlc41's Avatar
jlc41 jlc41 is offline
Vehicle: 2013 Ram 1500 CC
Trim Level: Laramie Crew
Color: Western Brown two tone (Hershey Bar)
Rep:39
jlc41 is on a distinguished road
I think he means more side wall therefore a more pliant ride.
tint, drop in bed liner, Avs window shades, Raptor bed rails, Dee Zee tail gate damper, Genos cabin air filter, Bak Roll-x cover, Weather tech mud flaps, Recon Xtrem tailgate bar, Moroso catch can, DoMore Slide Step, 5/16 Dual pin stripe, Reese lighted hitch cover, Master lock for hitch receiver, Truxedo bed lites, Hunter SS bull bar, Road Runner embroidered head rests, Plasticolor rear flaps with metal Ram logo, Mopar sill plates.
Old 10-06-2013, 01:56 PM
kmm316 kmm316 is offline
Color: Jazz Blue Pearlcoat
kmm316 is on a distinguished road
Check your window sticker asap and see what is suppose to be on your truck. When I was picking out mine I asked if I could trade rims and tires with another truck and he said no because the window sticker has to match according to the Monroney rule. This has become a huge problem as seen with the axle ratios...window sticker says 3:55 when the truck has a 3:21. Same thing applies with the tires; everything has to match up. Make sure you get what you paid for.
Old 10-06-2013, 02:59 PM
Color: Cherry Red
Rep:470
That was what I was thinking but both tires are the same tread width and the percentage of side wall is the same, 60%, so no increase in the side wall.
Old 10-06-2013, 07:11 PM
Carfreak 7186 Carfreak 7186 is offline
Vehicle: 2013 Ram 1500 Sport
Color: Copperhead Pearl
Rep:26
Carfreak 7186 is on a distinguished road
The sticker on the drivers door lists tire pressures for both sizes. I have the 20's, and it lists pressures for the 17's as well.
Old 10-06-2013, 07:36 PM
Rep:2657
17s are just a larger tire profile
20s are a lower tire profile
22s have the lowest tire profile
http://www.tirerack.com/tires/Select...dClar=Crew+Cab
this store lets you see what different wheels look like on Your vehicle, you can even change the color of the vehicle
http://www.tirerack.com/wheels/resul...dClar=Crew+Cab
