Old 10-07-2013, 12:54 AM
allhemi392 allhemi392 is offline
Vehicle: 2013 ram 1500 crew cab
Trim Level: jmajo25@aol.com
Color: jmajo25@aol.com
allhemi392 is on a distinguished road
Default brand new ram crew cab 4x2 lift kit or bodt lift kit
Hi im new to the ram formz and i was wondering whats the difference between and body lift 3in and a suspension lift and which one is better for minimal off roading and better for daily driving
Old 10-07-2013, 09:06 AM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Vehicle: 2005 Dodge Ram 1500
Rep:1056
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
a body lift will just take the cab and bed and put a 3 inch spacer in between them to make it look like its lifted but will no change any of your factory ride or suspension. where a suspension lift actually lifts all of you truck the same amount so the entire thing is lifted. the big difference will be price and look. with a body lift you will tend to see the awkward gaps in between the body and the frame a lot more and run the risk of looking slightly cheesy with lifting it that much. IMO if you can afford the suspension lift it is well worth the money
Old 10-25-2013, 05:17 PM
2011redrt 2011redrt is offline
Vehicle: 2014 RT
Trim Level: RT
Rep:25
2011redrt is on a distinguished road
You might try the lifted section.
