What size sockets - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Chassis - Drive Line - Suspension - Wheels and Tires - LEVELING
Old 10-07-2013, 01:33 AM
bavedoggs bavedoggs is offline
Vehicle: 2013 RAM 1500 EXPRESS
Rep:15
bavedoggs is on a distinguished road
Default What size sockets
Anybody know specifically what sized sockets are needed for a 5100 install? I bought a through-socket set and have regular sockets. But to be safe I 'd like to know what socket sizes I'll be using on my 2013 express. Thanks in advance guys!
Old 10-07-2013, 02:09 AM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
There's going to be a number of different ones you need. I believe the lower strut bolts are either 18mm or 21mm (maybe one of each). The upper ones are 14mm I believe and I think the retaining bolt is 14mm as well. The Bilstein nut is slightly larger. Either 15mm or 16mm. Then there's going to be a few wrenches you'll need as well to get the sway bar links off. Again, I don't remember the exact numbers but one is 7mm or 8mm, probably a 10mm on there. 13mm is very typical as well so make sure you have one of those.
Old 10-11-2013, 08:17 PM
sambrian2007 sambrian2007 is offline
Vehicle: 2013 1500 CC 4x4
Color: Redish
Rep:40
sambrian2007 is on a distinguished road
going to need a 24mm for the lower strut bolt. i did my level with a 24mm, 21mm, 18mm and 15mm.
Old 10-16-2013, 08:55 PM
wmorris4x4's Avatar
wmorris4x4 wmorris4x4 is offline
Vehicle: 2013 Ram 1500 Sport 4x4 5.7
Color: 1ea Bright CherryRed 1ea White
wmorris4x4 is on a distinguished road
if you do the rears, the upper is 22mm but i used a 13/16 thin wall sparkplug socket that made it a whole lot easier, i replaced the factory nuts with washer,lockwasher and nut and just zapped them tight with impact. Also cut hole in fender liner with 23/8 holesaw covered back with 600mph alum tape and painted blk
