Old 10-07-2013, 10:48 AM
Rexer's Avatar
Rexer Rexer is offline
Vehicle: Ram 1500
Rep:207
Rexer has a spectacular aura aboutRexer has a spectacular aura aboutRexer has a spectacular aura about
Default speed indicator on cruise flaw
Well...I've noticed this for some time now with the truck and I think that somebody mentioned it once before on the forum but there was never a follow up as to a fix (that I know of)...
Basically long story short, when setting the cruise control on my truck the EVIC is supposed to tell you the speed that the cruise control is locked on. Mine tells me it in MPH, which would be fine except that I'm Canadian and everything on the truck is in metric (for the EVIC). I can set it to KPH via the EVIC, and it will display in KPH, until the truck is shut off...then it defaults back to MPH. I brought the truck into the dealership to have the oil changed the other day and asked them to fix it at the same time. When I went to pick the truck back up later, I was told "the truck is ready for pickup, but we're not done with it". Turns out that the tech tried to fix it, he landed up talking with Chrysler Canada and was told that they're aware of the issue and are working for a fix.
Morale of the story....if you have a similar problem don't bother taking it to the dealership just yet...
Old 10-07-2013, 01:08 PM
Fliehigh's Avatar
Fliehigh Fliehigh is offline
Vehicle: 2013 Dodge Ram 1500
Fliehigh is on a distinguished road
Thank you posting this, I have the exact same issue and it has been driving me crazy. Although...... I now the translation between KPH and MPH A lot better than I use to!.
Old 10-07-2013, 02:37 PM
dparise's Avatar
dparise dparise is offline
Trim Level: ST w/SXT pkg
Color: Black Gold Metalic
dparise is on a distinguished road
I have the same issue, if you put the EVIC on speedometer, once the cruise is on, it will automatically change the readout to KM/H and it will stay that way until you turn your truck off. No a solution, but if you're going to be in the truck for more than a quick jaunt its a work around.
Old 10-07-2013, 02:38 PM
Bushmaster's Avatar
Bushmaster Bushmaster is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman 4x4 CC
Color: Bright White Clearcoat
Rep:102
Bushmaster will become famous soon enoughBushmaster will become famous soon enough
You would think trucks made for Canada would default to KPH.
Bakflip G2 tonneau cover, SunTek clear wrap complete front end, Trail FX wheel to wheel nerf bars, Huskyliner mudflaps, Weather Tech front floor mats, rear Recon mini lightbar,20% tint front door windows, 5% tint rear door/rear window, Smittybilt Lightbar with 10" Rigid LED lightbar
