Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > 4th Gen UConnect
Old 10-11-2013, 11:26 AM
Dracolan's Avatar
Dracolan Dracolan is offline
Vehicle: 2013 Ram
Trim Level: SLT Big Horn Pkg
Color: Cherry
Dracolan is on a distinguished road
Originally Posted by Bighorn453 View Post
You have to make sure you downloaded the correct file for your radio. If you have navigation, download the RA4 file. If you do not have navigation, download the RA3 file.
They're already .iso format so just put it how you got it onto a blank thumb drive. The thumb drive should be formatted as FAT32, so you may re-format it if you'd like to make sure it is.
I re-downloaded the file to make sure i got the right one and formatted the stick with FAT32 this time and it worked fine. Thanks.
Old 10-11-2013, 12:44 PM
datammwv datammwv is offline
Vehicle: 2013 Dodge Ram
Color: Gray
datammwv is on a distinguished road
Default If have added the 599 nav?
If you have had the dealer install the 599.00 navigation to your radio. Do i then need the RA4 vs RA3. Because when I input my VIN in wants to download RA3_13_38_52. I just don't want to loose my Navigation and have to schedule a day to complain and prove they have did it once for me and need to reload.
Old 10-11-2013, 12:56 PM
Bob225 Bob225 is offline
Vehicle: 2013 Ram Limited
Trim Level: Limited
Rep:43
Bob225 is on a distinguished road
Originally Posted by dawoodsman View Post
Maybe someone with the instructions can help (if they are detailed enough), but my thinking is if you have the correct file on your thumb/flash drive the system should start on its own after you place it in the truck's usb port and turn the truck key to accessories.
Do you have the right update? There's one of the radios without NAV and a different one for those with NAV.
I don't believe these things have to be a problem, but was told by Uconnect staff to make sure:
- you have no personal files on your USB thumb drive--this doesn't mean no files, they will have some software and a file or two on them that came with them. But delete any personal stuff.
- avoid high capacity drives. I was told 8 meg or less is best. The small ones are real cheap these days.
I don't know if either of those are required, I do think they help in getting the most clean and fast install you can. Plus I would bet the first thing Uconnect tech folks would do if you call with an installation isssue is to point to one of those two issues as the problem, even when it isn't.
If you did all that I'd be curious to see if logging in makes a difference for you. It is possible that is required to "prep" your radio I suppose. Would be nice if Dodge would tell you that if it is but they don't seem to be too inclined to make this easy for us or dealers!
I think I did it right. Downloaded from UConnect and extracted file then moved over to Flashdrive (which I reformated in FAT32) The flashdrive is 32g.
I made sure that truck was powered down and then hit the remote start twice to get it to run mode (foot of brake) and then put flashdrive in. Nothing happened. Radio just started playing like always. When I get home tongiht I will try it again now that I have registered radio with UConnect.
Old 10-11-2013, 01:37 PM
dieselman dieselman is offline
Vehicle: 2013 ram
Trim Level: sport
dieselman is on a distinguished road
Default not working
I have nav. but the link on the first page says moved or no longer avalible . Uconnect page just wont load can anyone send me the file for the update with nav, thanks dieselman0@rogers.com
Old 10-11-2013, 01:45 PM
Gonzo Gonzo is offline
Vehicle: 2013 Ram CC
Gonzo is on a distinguished road
Did mine last night and nothing happened. I figured the flash drive I was using (cheap brand, 8gb) was not responding with my radio. So, this morning I used a more reputable brand (sandisk) and BAM, got that sucker to work.
Don't be alarmed if your radio doesn't prompt you with the update option when you turn the key to "run." It took a couple of seconds for mine to pop up. Also, don't freak out if the radio just goes black and then goes back to the installation screen a couple of times while it does its thing.
Old 10-11-2013, 03:45 PM
The Crow 1994's Avatar
The Crow 1994 The Crow 1994 is offline
Vehicle: 2013 1500 Big Horn Crew 4x4
Trim Level: Hemi 5.7L w/8 Speed
Color: Copperhead Pearlcoat
Rep:56
The Crow 1994 will become famous soon enough
Just on observation, but wasn't the fan speed (climate) color on the screen orange before. Now, mine is white. Or, am I nuts?
Mod List: Line-X Platinum Spray-On Bedliner, BakFlip VP Tonneau Cover, TufTruck 1223-V HD Coil Springs, Bilstein 4600 Shocks, Air Lift 1000 Air Bags, Air Lift Wireless One Remote System with On-board Compressor, & Weathertech Digital Fit Floor Liners
Old 10-11-2013, 04:24 PM
macabra11's Avatar
macabra11 macabra11 is offline
Trim Level: Big Horn w/8 spd
Rep:23
macabra11 is on a distinguished road
I noticed that right away. For a second I didn't know if the fan was on since that color didn't show up.
Old 10-11-2013, 06:14 PM
Trim Level: Limited
Rep:43
Update completed. Took about 10 min.
Old 10-11-2013, 06:26 PM
BighornCheesehead BighornCheesehead is offline
Trim Level: Bighorn
BighornCheesehead is on a distinguished road
Tried this today. First time, the radio just started up and ignored the usb although the LED was flashing on the USB drive. Turned it off and on a couple times and the message popped up on the radio screen. It finished in about 12 minutes. Couldn't turn on the seat warmers while it updated, but everything else went smooth. The updates are just as expected. Best of all, when I deleted my Galaxy S4 (Tmobile) and added again, the message functionality is now available to me. Thanks to all for sharing their experiences.
Old 10-11-2013, 09:33 PM
Trim Level: Limited
Rep:43
First thing I noticed is my back up camera is clear. Blurry before the update.
