Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > 4th Gen UConnect
Old 10-22-2013, 12:18 PM
Coach Borne Coach Borne is offline
Color: Grey
Coach Borne is on a distinguished road
sorry about the repost this is my first attempt
Old 10-22-2013, 02:39 PM
Raz6200 Raz6200 is offline
Vehicle: 2013 Dodge Ram Crew Cab
Trim Level: Outdoorsman
Color: True Blue
Rep:61
Raz6200 will become famous soon enough
I went to the dealer on Saturday and had the update done. First they didn't even know this was available, but after I told them that I saw it on a forum they confirmed with Dodge that it is available. So made an appointment and dropped the truck off. Upon going back to pick the truck up they told me that they were able to do 2 of the 3 updates, the third update is a disc that they need to order from the factory(anyone her of this?) but they have no Ida when it will come in. So I leave and notice that I lost my FM presets(no big deal) but the AM/FM still sucks AND in spots where I never lost satellite I now lose it and get the message "acquiring signal". Also after reading all of these posts I decided to check to see what else did change and now I can change the icon on gps to a Ram(good so far) but then I can't seem to find the setting to turn the heat or a/c on with the auto start. Maybe I'm looking in the wrong spot but it seems to have disappeared. Not sure if this disc update will fix any of these issues. The last thing I had a question about was on the lower left half of the screen it says 11 items in settings, isn't it supposed to have 13?
Old 10-22-2013, 03:57 PM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:264
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
By the time you read this you should have discovered that all of your missing features are now back. A lot of features disappeared after the update but come back a short time later. FM presets are the only exception. You will need to reprogram them in.
Old 10-22-2013, 06:13 PM
Leveil22's Avatar
Leveil22 Leveil22 is offline
Color: Black and Tan
Leveil22 is on a distinguished road
Bump to borrow a update
Old 10-22-2013, 08:36 PM
dawoodsman dawoodsman is offline
Vehicle: 2013 Ram 1500 Crew
Color: True Blue Peal/Mineral Gray
Rep:92
dawoodsman will become famous soon enough
This doesn't make sense. The update can be downloaded by the dealer if the server it sits on is up and running, or the dealer can request a hard copy (DVD or flash drive loaded with the update).
If you don't want to just do it yourself (you can get the flash update yourself, stick it on a thumb drive which you place into the truck's drive and the update will run for you), I would call Uconnect customer service and explain your issue and what the dealer told you. Or if it works, just dial them through your truck under the "assist" setting.
Old 10-22-2013, 08:56 PM
Color: True Blue
Rep:61
I'll try and give them a call tomorrow.
Old 10-22-2013, 09:59 PM
Color: Grey
I downloaded the update today and it works. I don't really like the mirror update it seems incomplete and half thought.
Old 10-22-2013, 10:36 PM
nikeman nikeman is offline
Rep:91
Is Pandora available yet? What's the mirror update?
Old 10-22-2013, 11:05 PM
Kendo Kendo is offline
Vehicle: 2013 Ram
Kendo is on a distinguished road
I had the same balance/fade issue as SteelTownStang.
It now seems stable if I don't go into the audio controls. If I leave it alone everything is fine, but as soon as I go to the audio page it changes the balance/fade.
Old 10-23-2013, 01:33 PM
BlackedOutNinja's Avatar
BlackedOutNinja BlackedOutNinja is offline
Trim Level: sport
Rep:56
BlackedOutNinja will become famous soon enough
just got off the phone with a uconnect rep. Canaidans can only get it done at the dealership.
Brrraaaaaaapp!!!
