Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > 4th Gen UConnect
Old 10-23-2013, 03:08 PM
Raz6200 Raz6200 is offline
Vehicle: 2013 Dodge Ram Crew Cab
Trim Level: Outdoorsman
Color: True Blue
Rep:61
Raz6200 will become famous soon enough
Originally Posted by dawoodsman View Post
This doesn't make sense. The update can be downloaded by the dealer if the server it sits on is up and running, or the dealer can request a hard copy (DVD or flash drive loaded with the update).
If you don't want to just do it yourself (you can get the flash update yourself, stick it on a thumb drive which you place into the truck's drive and the update will run for you), I would call Uconnect customer service and explain your issue and what the dealer told you. Or if it works, just dial them through your truck under the "assist" setting.
I just got off the phone with uconnect and they told me that my truck does need the disc. They will send it to me in about 3 weeks or I an go online and just download it to a jump drive, which I did. Haven't had a chance to upload it yet, but will do so after work.
Old 10-25-2013, 12:30 PM
Ram Dave's Avatar
Ram Dave Ram Dave is offline
Vehicle: 2013 ram 1500 crew cab
Trim Level: Big horn
Color: Deep cherry red
Ram Dave is on a distinguished road
Default exceeded download
i messed around with this update and now when i put in my vin i get and exceeded download message.i just chaned the last number of the vin and it let me proceed with the download.is this ok to use?don't want to mess up my system.its working fine i just want to go ahead and update.thanks,david
Old 10-25-2013, 01:41 PM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:264
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
As long as the VIN owner's Ram is has the same radio it should work. I hope that you didn't take their last update option away from them though. You only get so many before Uconnect locks you out.
Old 10-25-2013, 01:48 PM
Coach Borne Coach Borne is offline
Color: Grey
Coach Borne is on a distinguished road
heated mirror can now be turned on and off using uconnect but it looks unfinished
Old 10-25-2013, 02:56 PM
MN13Laramie's Avatar
MN13Laramie MN13Laramie is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Copperhead
Rep:43
MN13Laramie is on a distinguished road
So one thing that my radio did when I first got my truck was turn HD Radio off everytime I restarted the truck. 13.19 fixed that, and it defaults to HD Radio all the time now, which I think is good. It looks like this "fix" now turns HD off by default?
HD now defaults to 'OFF' for reduced complaints about 'channel switching'.
Can anyone verify if this is true with the update? Why don't they just make this an option so the user can choose?
Thanks,
Mike
Mike
2013 1500 - Copperhead
Old 10-25-2013, 07:57 PM
batster batster is offline
Vehicle: 2013 Ram Hemi
Trim Level: Laramie Longhorn 4x4
Rep:17
batster is on a distinguished road
Default Vic not showing engine vitals
All went well with the update, no errors. The volume was lower on huge radio and media than before and I discovered the equalizer reset itself to factory, after making the adjustments the sound is good again.
Following the update I can no longer look at my engine and transmission temps. Am I alone?
Old 10-25-2013, 10:23 PM
Rep:17
I feel stupid, I found the setting I was missing. My evic was set on tire pressure screen. I just needed to scroll back to engine vitals.
Old 10-25-2013, 11:02 PM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
Originally Posted by Kendo View Post
I had the same balance/fade issue as SteelTownStang.
It now seems stable if I don't go into the audio controls. If I leave it alone everything is fine, but as soon as I go to the audio page it changes the balance/fade.
I had the dealership reload the update and my fade/balance continues to reset after each ignition cycle. Can someone please see if you're having the same issue that Kendo and I are experiencing? Otherwise, everything else seems to be functioning properly...
Oh, and like others reported- the volume w/the CD is much louder than the radio.
Lastly, my heated seats and steering wheel do not come on w/the remote start. I have the feature enabled... I remember reading somewhere that the outside temp has the be <40 degrees. Does this seem correct?
Thanks!
MODS: Magnaflow Cat-Back Exhaust, aFe Stage II CAI, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Aries Stealth Bull Bar, & KC SlimLites.
Old 10-26-2013, 12:09 AM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:545
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
-40?!?!? That doesn't seem normal at all. The only people who'd ever be able to use it would be people in North Canada and inland Alaska.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread), Matte black Plasti-dipped center console bezel, BT catch can.
Old 10-26-2013, 03:36 AM
Rep:264
It's 40F or lower for the auto heat to turn on and 80F or higher for the auto cool to come on.
