Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > 4th Gen UConnect
Old 10-09-2013, 10:08 PM
JamoMacD JamoMacD is offline
Vehicle: 2011 dodge ram
Color: Blue
JamoMacD is on a distinguished road
Is it best to let dealer do this?
Old 10-09-2013, 10:35 PM
Lizardking Lizardking is offline
Vehicle: 2013 Ram 2500 Cummins
Rep:41
Lizardking is on a distinguished road
I did mine while driving down the road....worked like a champ.
Old 10-09-2013, 10:42 PM
Longhorn123 Longhorn123 is offline
Vehicle: 2013 Dodge Longhorn
Longhorn123 is on a distinguished road
Thank you Bighorn453. I used your download and it was easy. Took 15-20 min to download from Mega. At the end of the download, it asked me where to save it. I saved to a USB Flashdrive and then went outside, placed the stick in the USB port, turned the ignition On to accessories, but did not start the truck. After a few seconds the screen came up asking me if I wanted to do the update. I clicked yes and the rest was easy. Took about fifteen minutes. After it was all done, the radio came on and started playing music so I pulled the stick and started the engine. All good here. Thanks again for your help!!
Old 10-10-2013, 02:55 AM
Bighorn453 Bighorn453 is offline
Vehicle: 2013 Ram 1500 Big Horn
Rep:59
Bighorn453 will become famous soon enough
Exclamation
THE FOLLOWING IS REQUIRED IN ORDER TO UPDATE:
- The extracted update file (swdl.iso).
- A BLANK USB thumb drive (at least 1GB).
(Make sure there are no other files on it.)
DOWNLOAD UCONNECT UPDATE 13.38.52
- Official uConnect Update Site:
https://rsur.extra.chrysler.com/rsur/Uconnect.do
(If the above site is used, you must make sure to run the self-extracting .exe which you've downloaded, and put the extracted .iso file onto the USB drive!)
OR
- RA3 8.4A (Without Navigation):
https://mega.co.nz/#!HpJmFYyL!aCqb6V...veOHurzODPBbko
- RA4 8.4AN (WITH Navigation):
https://mega.co.nz/#!H1xQzZ4T!fNv7Qn...LZF9x0aXpMBfiA
(Please DO NOT share these links outside of this forum!)
Once you transfer the software update file (swdl.iso) to the USB drive, follow the instructions (attached below) to begin installation process.
The update should take approximately 10-15 minutes to complete.
SOME ANSWERS TO THE FREQUENTLY ASKED QUESTIONS
- Make sure if you download the file from a link other than the official uConnect site that you download the proper file for your radio (RA3 or RA4).
- If the update seems to stop around 40% on the Air Card Update (Unit 10), this is normal. It is a big part of the update. BE PATIENT!
- If your radio reboots at all during installation, this is fine. It should reboot and continue the installation process.
- You may notice some settings missing at first, but they will come back shortly (usually within a few minutes).
- Give the radio up to 24 hours to allow it to communicate with other modules and restore everything to how it was.
- Should anything go wrong, you can restart from the beginning.
Most Noticeable Changes/Fixes (Full Changelog Below)
- Outbound texting from many phones.
- Addition of mirror dim on/off control.
- Pop up menu enabled for Voice Recognition.
- Simplified layouts for apps.
- General Nav improvements.
- Song shuffle recalls properly on restart.
- Screen is much more responsive.
- 3G icon has blue halo around it.
FULL Change Log (Issues Addressed)
Radio reset, screen lockup, blank screen or sluggish system response time.
Compass indicator turns off.
Touch screen shut down message.
Radio surround sound will not stay ON.
Driver memory feature causes Sirius XM failure
Loss of radio presets.
Battery drain - due to radio remains on.
Uconnect apps don't load.
AM/FM popping noises and/or static.
Backup camera display is blank.
Compass direction may be incorrect.
Vehicle's Icon changes on the navigation map.
Loss of vehicle position on NAV map.
“Vehicle Phone Requires Service” message appears.
Nav turn-by-turn enhancements.
Nav map guidance enhancements.
Nav text overlaps in detour menu.
Nav map, vehicle location enhancements in areas with low GPS signals.
Navigation shows vehicle in San Antonio, TX.
Screen only displays startup Logo.
Screen Half Black Half White after update.
Radio locked up after attempting to update with a corrupted or incorrect USB update stick.
Phone/Navigation Overlay Screen Freeze (WK only).
Heated seat controls through radio do not function/display correctly during startup.
Speed controlled volume not functioning correctly.
Steering Wheel Control operation corrected at startup.
Tuner mutes on startup.
HD now defaults to 'OFF' for reduced complaints about 'channel switching'.
"LO” temps displayed upon each vehicle start.
HMI Lock up in SXM mode after ignition cycle.
Voice Recognition (VR) enhancements.
Point of interest screen locks up.
Error message when plugging in iPod.
Balance/fade setting changes after ignition cycle.
Clock enhancements.
Phone book enhancements.
Rear climate control display frozen.
Translation enhancements.
Erratic pop ups in HMI.
Added Teleprompter.
Bluetooth, phone, iPod, auto streaming, connecting/disconnecting enhancements.
Phone quality and pairing enhancements.
Audio control locked after using VR feature.
Travel link enhancements.
File Type: pdf RAM_Truck_Software_Update_Instructions_RS1.pdf (1.26 MB, 193 views)
Old 10-10-2013, 11:25 AM
macabra11's Avatar
macabra11 macabra11 is offline
Trim Level: Big Horn w/8 spd
Rep:23
macabra11 is on a distinguished road
I did my update last night and it was done in about 15 mins. No hiccups or issues aside from losing AM/FM presets. I haven't had a chance to play with it much, but everything seems to be working properly.
Old 10-10-2013, 11:58 AM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:616
Thunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to all
I think I'll just have the dealer update me when I get my oil changed.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Matte black Plasti-dipped center console bezel, BT catch can, Corsa 14405 cat back (video) Tuftruck 1223V progressive rear coils.
Old 10-10-2013, 12:47 PM
dawoodsman dawoodsman is offline
Vehicle: 2013 Ram 1500 Crew
Trim Level: Outdoorsman
Color: True Blue Peal/Mineral Gray
Rep:92
dawoodsman will become famous soon enough
NOOOOOOOOOO!
Not right now at least. Will explain when I have time. I lost over an hour at the dealer yesterday--still do not have any update.
Old 10-10-2013, 01:00 PM
Rep:616
Originally Posted by dawoodsman View Post
NOOOOOOOOOO!
........Or maybe not
Old 10-10-2013, 01:58 PM
Rep:92
Ok had a bit of time. I hope I can get this post in before I am booted out by the system again. Maybe will post in several pieces.
My personal status I will explain in a bit, but I still have no update. THis after visiting the dealership for the 2nd time--taking time off of work--per the advice of Ram Uconnect people.
For anyone still w/o the update, the server is still having issues.
This means those of us trying to download it ourselves are SOL too.
Here's what I'd recommend after a long still unresolved experience: Call your dealer, ask them to first get the update downloaded IN THEIR HANDS--then WHEN THEY HAVE THE UPDATE IN THEIR HANDS--have them call you so you can set up an appointment.
You'll get frustrated when you visit the dealer for an update that is available and the dealer can't get it for hours if at all due to server issues. make sure they have it in hand first!
Old 10-10-2013, 02:08 PM
Rep:92
hey that made it through!
Now for more info, this gleaned from several calls directly to Ram Customer service and Uconnect tech support folks in the last couple of days.
1) If you want to download the update yourself,
a) you can't if the server is down
1a continued--NO ONE at Uconnect or your dealer will trouble themself with the simple request of notifying you when the server is back up. You just have to keep trying again and again (or maybe folks here can keep us updated!)
b) any major browser should work, BUT anything that blocks pop-ups will have to be turned off for the download to work
c) you should have an empty (i.e. no personal files on it) USB (thumb) drive to stick the downloaded files on
d) the USB (thumb) drive should ideally be smaller in size, I was told 8 meg or smaller is better
e) when you follow the instrutions and allow flash transfer to your truck, it can take awhile.
f) some functions may be reset to the base level, meaning you will have to reset them to where you want them
g) nothing should disappear entirely, but in the short term that is possible--give the truck a few hours to see if anything that disappears doesn't come back. It should. Remember with these trucks your truck is communicating with the sattelites even when turned off, as long as the battery is connected. The download/fix process may still be functioning after you pull the thumb drive from the truck
h) some of the problems the update will fix are stored for use if needed later. I.e, if you don't currently have the problem nothing may change for that function--if you develop it in the future the system will know how to fix it for you without any intervention by you. I didn't get details on this but it makes sense when you understand the constant link between your truck and uconnect as long as the battery is connected.
Hopefully I captured everything correctly and this helps someone.
