Old 10-07-2013, 05:14 PM
trayne's Avatar
trayne trayne is offline
Vehicle: 2013 Ram Crew Cab 4x4
Rep:31
trayne is on a distinguished road
Default That damn dam
I've seen a couple other posts about this weeks ago but I can't find them now. I've been thinking of removing the lower air dam on my '13 Express CC. Is there any reason not to?
Flowmaster 50 series, K&N drop-in, Mopar chrome bed rails, Stainless step rails, DIY CAI, so far...
Old 10-07-2013, 05:32 PM
Rep:2608
as far as i know, it just makes your Ram more aerodynamic, giving you better gas mileage
To improve the fuel’s economics, the company makes its front air dam longer. New thermo-plastics materials which is expected to prevent the truck from breakage when contact with curbs, rocks and other objects.
http://topcarslist.com/2013-dodge-ra...hottest-truck/
Old 10-08-2013, 01:26 AM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:229
Ramzaq has a spectacular aura aboutRamzaq has a spectacular aura aboutRamzaq has a spectacular aura about
True, it helps with aerodynamics to smooth the flow under the vehicle and keep the stream away from the under body parts which will cause turbulence and drag. In conjunction with less turbulence it helps pull the air through the engine compartment more efficiently helping with engine and trans cooling.
But many people take them off and have no problems.
