Old 10-07-2013, 10:05 PM
CTXDodge's Avatar
CTXDodge CTXDodge is offline
Vehicle: 2009 Dodge Ram 1500
CTXDodge is on a distinguished road
Question Noise after level.
Took the truck to a local shop this last Saturday and they installed a 2" front leveling kit for me. Drove it yesterday and had no problems. Drove it down to the store this evening and over to my parents house and it's making a humming/whining noise. It's doing this when I turn either right or left, then when I straighten out it makes it for just a little bit and then goes away. What is going on and what am I hearing? I have not had an alignment done on it yet as I am going to have a 1.5" body lift installed hopefully this weekend and was going to have it aligned after that. Please help...now I'm wondering if something got messed up when they put in the spacers.
Old 10-07-2013, 11:16 PM
CTXDodge's Avatar
One thing I wanted to add. The front now sits at 37" from ground to top of wheel well and back sits 37.25" from ground to top of wheel well. Is that enough rake? Could this be causing any problems with sound? I think probably not but I don't know.
Old 10-11-2013, 08:57 AM
WileyBob WileyBob is offline
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
WileyBob is on a distinguished road
It's most likely the truck being out of alignment, and you're hearing the tires scrubbing against the pavement. My truck made a similar sound until I got it aligned, then it went away and the handling was actually better than stock in my opinion (perhaps the factory tolerances are wider than the ones the alignment shop used). Good luck! I'm pretty sure an alignment will cure this issue, and the sooner you get it done the less "unusual" wear you will put on your tires.
You can do the alignment any time, before or after the body lift. The alignment isn't affected by body changes, you are aligning the wheels to the frame so it drives correctly. The sooner you do it, the better.
Old 10-14-2013, 03:03 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
I wonder if what you're hearing is the power steering pump having to work harder because the alignment is a bit outta whack. Just a thought.
Old 10-16-2013, 09:50 PM
wmorris4x4's Avatar
wmorris4x4 wmorris4x4 is offline
Vehicle: 2013 Ram 1500 Sport 4x4 5.7
Color: 1ea Bright CherryRed 1ea White
wmorris4x4 is on a distinguished road
my 2.1 lift knocked the camber out about 10deg, alignment brought it back to 0 with no adverse symptoms. With that much camber tires wont last long either, better get it aligned sooner than later.
Old 10-20-2013, 08:58 PM
CTXDodge's Avatar
Thanks for the responses. An alignment took care of the problem.
Old 10-21-2013, 01:47 AM
God Bless Texas!
Rep:2929
Voonderbar! Thanks for the update.
