Old 11-07-2013, 08:01 PM
Alaskan Alaskan is offline
Vehicle: 2009 Dodge Ram 15004WD Laramie
Color: Sunburst Orange
Alaskan is on a distinguished road
Default Tow Hook and bolt size - Mopar OEM 2009 Dodge Ram 1500
Hi Folks!
Can anyone tell me what kind (grade, thread, etc.) and size (length and diameter) bolts hold the Mopar OEM tow hooks to the front sub frame on a 2009 Dodge Ram 1500 4WD? Also, I need to know the thickness of the tow hook "tab" that mounts to the sub frame.
I am looking at mounting a front receiver hitch and I'd prefer to keep the existing tow hooks rather than remove them as the install directions day for the Kirt 31374 hitch. I'd rather install longer bolts to go through both the front receiver hitch mount tabs AND the existing tow hook mount tab and then add a spacer of the same thickness as the existing tow hook tabs to the rear where the front mount receiver hitch will mount to (after drilling a hole) so the hitch will go on basically level and not angled down (as it would if I did not add a spacer on the rear to match the difference in the front). So, I need to know what bolts to get and what size (thickness to match the thickness of the existing tow hook tabs) spacers to get to make this work. Confused yet? haha. Hope someone can help. Thanks! Love the forum.
Old 11-08-2013, 10:34 PM
dbuzz77's Avatar
dbuzz77 dbuzz77 is offline
Vehicle: 2009 Ram RCSB 4x4
Color: Stone White
Rep:100
dbuzz77 will become famous soon enoughdbuzz77 will become famous soon enough
if you mean the bolts holding the tow hooks on to the stanchions behind the bumper (bolting straight up, not to the bumper mount) i just bought some. 12M x 1.5 x 65mm
2009 RCSB Sport, SC Cortex, K&N air box, all Amsoil fluids, Fan delete, Grounded TB, homemade catch can, homemade gps mount, Fastman TB, EZ down tailgate, Bully hitch step
Then God made a hemi, and knew that it was good.
Old 11-10-2013, 05:35 AM
Thanks a bunch!
Anyone know the thickness/height of the tow hook "tabs" the bolt must run through?
2009 ram 1500, front hitch mount, sub frame, tow hook
