Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 10-09-2013, 12:47 AM
bkyzn5 bkyzn5 is offline
Vehicle: 1984 W250
Trim Level: old bastard
Color: grey
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
bkyzn5 is on a distinguished road
Default 84 W250 front hub/rotor?
Does'nt the hub come off of the rotor, and HOW? Please and thank you
Old 10-09-2013, 01:24 AM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Do you mean rotor come off the hub? The answer would be no. Bearings are in the rotor, they are one piece. You have to pull the dust cover off, remove the cotter pin and then the hub nut, then the rotor will slide off the hub with the bearing attached.
Old 10-09-2013, 01:52 PM
Vehicle: 1984 W250
Color: grey
Yes yes thats what i mean. Trying to replace the rotor but its not possible at the moment unless these are two separate parts. What dust cover are you referring to?
Old 10-09-2013, 01:55 PM
Vehicle: 1984 W250
Color: grey
Trying to attach a pic but the m***&^*#! wont upload for some reason. It seems the studs are pressed into the rotor from the backside and the hub is just setting in it, over the studs. It looks like the two should be pried apart but nothing will budge.
Old 10-09-2013, 02:07 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Did you try wacking it between the studs with a BFH?
Just for future reference...It's a lot easier to pull the rotor off the hub while it's still on the truck.
RRJ! tell 'em how to post a picture!
There's a few good tutorials in the "Suggestions-Feedback-Tech Support"...(then click) "How To's" up top, or follow this link: http://ramforumz.com/forumdisplay.php?f=73
Old 10-10-2013, 12:49 AM
Rep:2929
I remember something about putting your left foot in and shaking it all about.
Old 10-13-2013, 12:25 AM
Vehicle: 1984 W250
Color: grey
Yes yes it was just a BFH that needed and it did the trick, knocked the studs through and it came right off. Thanks!! Picked up a 20 gal parts washer today to lower the intensity on this little job a ton.
Hey now I figured out HOW to upload a pic, but was encountering some kind of error. Comments like that typical of a Texan..
Old 10-13-2013, 12:50 AM
Rep:2929
Hey! I resemble that remark!
