Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 10-09-2013, 01:05 PM
Marcelo's Avatar
Marcelo Marcelo is offline
Vehicle: 2005 5.7L HEMI
Trim Level: SLT Quad Cab 4WD
Color: Flame red
Rep:34
Marcelo is on a distinguished road
Question 2005 Tie rod ends issue...
Hi, folks...
Just have to change worn outer tie rod ends, and by a quick search on eBay I found at least two different types: outside and inside threaded, i.e. to fix with a nut or a bolt. This referring to the vertical end.
This is a pair of inner threaded:
http://www.ebay.com/itm/2-Set-TRW-ES...746678&vxp=mtr
And this one is outer threaded:
http://www.ebay.com/itm/Mevotech-MS2...b6865b&vxp=mtr
Moreover I see some vendors list them as RH or LH... aren't they supposed to be identical???
Please any help to clarify this will be welcome...
Old 10-10-2013, 12:42 AM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
You'll probably get more exposure in the 2002-2008 section. This is for 94-01 trucks which have a totally different steering setup.
