Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 10-10-2013, 04:02 PM
wmorris4x4's Avatar
wmorris4x4 wmorris4x4 is offline
Vehicle: 2013 Ram 1500 Sport 4x4 5.7
Color: 1ea Bright CherryRed 1ea White
wmorris4x4 is on a distinguished road
Default Shock Replacement 2013 1500 4x4
To start of with, the YAHOO who designed the upper rear shock bolt setup ought to be taken out behind the shed and have his ass whipped. That said got it done,used 13/16 thinwall spark plug socket to get to inside nut, 23/8 hole saw thru the fender liner to get to bolt head, replaced factory lock nut with new nut and lock washer an tightend with impact. Put Bilsteins frt and rear,lifted the frt 2.1 with the 5100 series shocks. Oh and covered hole back with 600mph alum tape and painted Black.
Old 10-10-2013, 05:48 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Sweet, any pic of the ride?
Old 10-10-2013, 05:58 PM
bavedoggs bavedoggs is offline
Vehicle: 2013 RAM 1500 EXPRESS
Rep:15
bavedoggs is on a distinguished road
Awesome. How difficult was the front swap? What size sockets and/or tools did you use. I'm doing the front soon.
Old 10-10-2013, 06:00 PM
wmorris4x4's Avatar
Default The Red Truck
nothing fancy, Bilsteins, F1 BakFlip, Cooper Zeons, CargoMate bedslide, tints all the way around , Black Leather interior, Heavy Foot
Old 10-10-2013, 06:05 PM
wmorris4x4's Avatar
Default Frts done
I had the Frts done, charged me 120.00 for both sides, frt end alignment 62.00, hell i had to buy a spring compressor, just wasnt worth the trouble. took them 2hrs start to finish, takes me that long to get started, wish i hadnt done the back, im sore as hell.
Old 10-10-2013, 06:09 PM
wmorris4x4's Avatar
Default smart
if your smart have it done unless you dont have anything else to do, will need good spring compressor
Old 10-10-2013, 06:23 PM
Nburd's Avatar
Nburd Nburd is offline
Vehicle: 2013 ram 1500
Trim Level: Express crew
Color: Mineral gray
Rep:231
Nburd has a spectacular aura aboutNburd has a spectacular aura aboutNburd has a spectacular aura about
So this will lift the front without the use of spacers?
Nburd.13 Ram 1500 Express Crew 4x4. Mineral Gray, Chrome 20s, Cloth, Uconnect 5.0, 7" Evic
Old 10-10-2013, 06:27 PM
wmorris4x4's Avatar
Default bilsteins 5100
Yes will adjust from stock to 2.75 lift 4 settings at .75 increments, set at 2.1 allows just a bit of nose low, i drop a trailer on and it sets level , also have a set of 1000lb airbags in rear at 50psi
Old 10-10-2013, 07:30 PM
Rep:15
I cant find anybody to install for less than $300 around here. Thats just the fronts.
Did you have the airbags inflated when you dropped the trailer on?
I also have the airlift 1000's and am wondering what size to put the shock setting at. I tow a boat and don't want the truck to sag.
Old 10-10-2013, 07:51 PM
wmorris4x4's Avatar
rears arnt adj just the frts, i put on trailer aired to level and i leave them there, it took 50psi to level so no sag. 300.00 wow out here in farm country it,s not near as bad as that. Rears are a lot softer than the old style spring set up, but rides better. Frt setting i went with the 2.1 instead of the 2.75 some folks say there trucks vibrate at the CV,s on the 2.75 so i just went with what everybody said worked with no problems the 2.1 i did put 2in blocks in my 2011 and had no problems at that height, but i went with the the Bilseins this time as factory shocks suck and dont last but 15-20,000 mi
