Nerf bar question 2002 Quadcab - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 10-10-2013, 08:21 PM
1911heaven's Avatar
1911heaven 1911heaven is offline
Vehicle: 2002 Dodge Ram SLT 4.7L QC 2WD
1911heaven is on a distinguished road
Default Nerf bar question 2002 Quadcab
Hello everyone need some thoughts and or opinions here!
I just purchased some oem 3" step bars from a friend
For my 2002 quadcab. Truck they came off of was sold and my friend
Thought it was an '08 but I think it was an '09. Got the brackets and the bars
Bolted on although on an '02 there were no
Hex holes below the holes that the T bolts
Fit but I made it work and the brace. Bolted
Up tight so the front is solid. My problem is with the rear- the bracket is held on
By one T bolt and there is no brace to bolt to
The undercarriage like the front and I am
Uncomfortable with it because if I step back
There I can see a slight give in the whole bar.
I need to fabricate a brace but what's funny is the
Undercarriage bolt doesn't fall straight in line with
The bracket so I may have to bolt it to the frame which I don't want to go
Drilling holes in if not necessary. Can't get a kit for these bars because they
Stop short just after the 90 degree bend so a different set
Of bars would be in order if I can't fabricate a brace which I am trying to
Avoid. So does anyone have any recommendations? I know I should have examined the bracket situation closer but I am so close to a fix to give up! Any advice or thoughts will be much appreciated!
Old 10-11-2013, 05:05 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
I couldn't say without having a look at it. But this will bump you to the top.
Old 10-16-2013, 12:51 PM
1911heaven's Avatar
Thanks for the reply. It is kinda hard without seeing. Pretty much decided I'm going to just sell these bars and get some that actually fit a 2002.
