Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Place your Ad Here!
Old 10-11-2013, 02:03 AM
ttootone ttootone is offline
Vehicle: 2012 Ram 3500
Trim Level: Larame
Color: grey
ttootone is on a distinguished road
Default need info on brake controler
I am looking for information on how to disable the factory trailer brake controller, as it does not work on trailers equipped with disc brakes?
Thanks in advance, Tom
Old 10-11-2013, 08:29 AM
Asur Asur is offline
Vehicle: .
Rep:4373
You can have the dealer disable the trailer brake unit.
Old 10-11-2013, 07:40 PM
TurboCup87 TurboCup87 is offline
Vehicle: 2012 1500 Sport Crew 4x4
Color: Blue
Rep:28
TurboCup87 is on a distinguished road
Pull the fuse?
I believe that most trailer disc brakes are hydraulic. Electric brake controllers have no role in activating hydraulic brakes. You probably don't need to do anything.
Old 10-11-2013, 07:46 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:86
topgun will become famous soon enough
Why does the controller not work? On your truck, you should be able to select EOH Light and Heavy as well as Light and Heavy Electric from the EVIC.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Husky X-Act Contour Floor Mats, Cooper AT3 285/70/R17's, Moroso Catch Can
Old 10-11-2013, 07:51 PM
Vehicle: .
Rep:4373
Some controllers just will not work well with trailer disk breaks, I have read that many disk break systems will not work well with certain type of controllers and the Ram one does not like them. Something to do with the pressure the lines need to do the breaking, not the same as drum units, I have read most will disable the Electronic braking and get a trailer with a hydrolic brake head on the trailer.
Old 10-11-2013, 07:57 PM
topgun's Avatar
Rep:86
Sure they do. That is what the EOH setting is for as most hydraulic trailer discs are controlled by an electric pump. EOH is Electric Over Hydraulic.
Old 10-11-2013, 08:06 PM
topgun's Avatar
Rep:86
2012 and up 2500+ trucks have the EOH settings. The Cummins guys say it does indeed work fine unlike previous years.
Old 10-11-2013, 10:48 PM
Color: Blue
Rep:28
Tell that to the many thousands of UHaul trailers with hydraulic disc brakes
Old 10-11-2013, 10:55 PM
topgun's Avatar
Rep:86
You are talking surge brakes. They are completely different and do not require a brake controller.
Old 10-12-2013, 02:13 PM
Color: Blue
Rep:28
Exactly!
