Old 10-11-2013, 04:25 PM
Xd2311 Xd2311 is offline
Vehicle: 2012 Ram CC short bed
Trim Level: Big Horn SLT
Color: Deep cherry red
Xd2311 is on a distinguished road
Default Need rear spring / towing education
I will be getting the Bilsteins to do a level on my truck. Will most likely use the 2.1 setting. In the summer I pull a pontoon boat, about 6k lbs.
I have seen people recomend better springs and/or air bags to combat sag when leveled.
Do I keep the stock springs and add some Air Lift 1000's...
Do I upgrade to some TTC-1223V TufTruck springs...
or get both???
If I do any of the above, would I be ok to take the shocks up to the 2.8 setting?
What's the difference between a variable rate spring and a standard in this type of application?
Old 10-11-2013, 07:50 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Color: Deep Cherry Red
Rep:85
APSTRAM will become famous soon enough
I added the ttc-1223V springs to my 2011 1500 and I really liked the way they handled the load, towing was much improved without the rear sag. I also set the front shocks at 2.1 and with the new rear springs I had a slight rake but I liked the look.
Old 10-11-2013, 08:00 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
The height you want to set your Bilsteins at should be determined by your fender heights now. Since not all trucks come exactly the same from the factory you'll want to measure yours to find out how much rake you have and then go from there. You're going to want to retain at least 0.5" to avoid looking nose high but since you plan on towing a lot I'd stick closer to 1" of take.
As far as the rear suspension goes I would put Airlift bags or a TLC kit on way before I'd change out the springs. You're only towing 6k so airbags will handle that no problem. There's no sense in changing out the springs for a worse ride quality all winter when you aren't towing.
I had the Airlifts in my 1500 and they helped a lot with the towing I did (approx 4500 pounds). Check out my Airlift thread linked in my signature below for more information on that.
Since you plan on towing more weight and probably more frequently the TLC kit might be a better option for you. They have a higher capacity as they are an external bag, not an in coil bag.
Old 10-18-2013, 08:08 PM
point point is offline
Vehicle: 2013 RAM 1500
Color: max steel
point is on a distinguished road
I too am looking to put a set Bilsteins 5100 on my '13 1500 and want to maintain
around a 2" rake. Would spacers for the rear coils be a viable option. A guy I
talked to told me to stay away from spacers and go with heavier coils but I
don't want to lose the ride. lol It's one of the reasons I bought the truck. I'm
not planning on towing for a couple of years yet so airbags seem like over kill.
Old 10-18-2013, 09:15 PM
Kindanocturnal's Avatar
Kindanocturnal Kindanocturnal is offline
Color: Black/sandstone
Rep:38
Kindanocturnal is on a distinguished road
I run the firestone airbags and have an inboard air compressor. This way I pump them up when I tow and let it out when I don't. I tow 6500-8000 lbs pretty frequently but I didn't want the stiff ride you get from going with a stiffer spring. Very easy to install and you can always do just the bags if you do not tow as frequently as I do.
Old 10-18-2013, 10:01 PM
Rep:2036
You can put the Bilsteins on without lifting the front end at all if you want to maintain rake. You don't need to lift the back.... Or are you trying to clear bigger tires?
Old 10-18-2013, 11:11 PM
Color: max steel
will be clearing bigger tires, my truck has a 3 1/8" rake, so a 2" front level with
the Bilsteins will probably be fine until I buy a trailer.
