Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 08-22-2013, 12:34 PM
gustapus gustapus is offline
Vehicle: 2013 Dodge Ram 1500 4.7L
Trim Level: Tradesman
gustapus is on a distinguished road
Default 1-2 Shift Bog/Hesitation
I have a 2013 1500 with the 4.7L Flex-Fuel engine and 6-speed tranny. There is a pronounced "bog" or hesitation when coming off the line when the tranny shift from first to second. Sometimes it's worse than others. Dealer clams they submitted a "Star" inquiry and were told it was a specific program to extend tranny/gear life. I find this a probable fob-off from the factory. Any similar experience with your drivetrain, and any fixes?
Old 08-27-2013, 07:30 AM
TransEngineer TransEngineer is online now
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
We do torque manage the engine (momentarily reduce engine torque) during the last half of power-on upshifts, including the 1-2. Your dealer should be able to monitor the amount of torque reduction using their scan tool (this variable is called Delta Torque and is in Nm). They can also monitor the actual engine torque (called Actual Torque [in Nm] or Engine Torque [in ft-lbs]). They can also monitor the trans input torque (called Turbine Torque I-Gear and is in ft-lbs). So they could drive with you and record these values, then show you the actual amount of torque reduction, and how long it lasts for (typically a few hundred milliseconds). They could also see if they are in line with other similar trucks.
Old 10-10-2013, 03:50 PM
Vulture666 Vulture666 is offline
Rep:34
Vulture666 is on a distinguished road
I just got my 13' 1500 with the 4.7 engine. Mine also noticeably bogs when shifting from 2nd into 3rd. The RPM's drop right back to about 800-1000 and it has to work hard to pick up speed.
Old 10-10-2013, 09:34 PM
09HemiCrew 09HemiCrew is offline
Vehicle: 2009 Dodge Ram
Rep:75
09HemiCrew will become famous soon enough
Torque management.
2009 Crew Cab 4x4 Laramie - 4.56 gears, Detroit Truetrac, Diablosport Trinity
Old 02-24-2015, 12:34 PM
blackramqc blackramqc is offline
Vehicle: Ram 1500 2015
blackramqc is on a distinguished road
I have a ram 2013 4.7 who do the same thing between the 2rd and 3rd gear like a bogging sound. Do you learn something new from your dealer. I already went to my dealer and they found nothing but i think it's not normal.
