Old 10-14-2013, 03:04 PM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
next is that since it only has 2 pre-outs, you CANNOT easily add a 4 channel amp AND a sub amp. Some 4 channel amps have a sub output in it, that would work, but then the sub settings on the stereo don't apply. You can always add a crossover into the mix and do some weird things that could allow you to add both amps. But in the long run I would have found a cheaper stereo with 3 outs (FR,R,SUB) instead of the 2 where its FR,R/S.
From the looks of yours, it is the cheaper model of the same one I posted. Cheaper probably because it doesn't offer Bluetooth. I think I will continue my search for a head unit, and perferably one with 3 RCA ports. I may only use one, but knowing I can add more amplifiers is nice.
I might rethink my whole speaker configuration as well.
Old 10-14-2013, 03:44 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
personally I regret not putting some more money into it for one with 3 RCAs. cause when i do actually amp my speakers, ill have to either buy a new headunit or something else to make it work.
Green Interior LEDs
Old 10-16-2013, 07:17 AM
Color: Blue
Rep:95
That is my thought too, but since I want to start off with an equlaizer in my system, a head unit with only 2 RCA jack sets (front/Rear) will suffice since the equalizer I am looking at has inputs for only f/r but f/r and bass outputs. But yes I agree with you, I think 3 RCA outputs would be better, so like you said I can control the bass through the deck instead of looking for a control knob elsewhere.
