Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 10-12-2013, 12:52 PM
Rugby1521 Rugby1521 is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: Outdoorsman
Rugby1521 is on a distinguished road
Default Right Tire Choice
Hey all
Looking to purchase off-road tires for my 2013 1500 Outdoorsman. This summer i put the Rough Country Leveling kit on. Want to change out the stock tires for a set of MT's. I have been looking at the Cooper SST's, Toyo Open Country's, Nitto Trail Grappler's, Or Dick Cepek Mud Country's. I have the stock 20'' rims, currently. Also not sure if i will be able to get 35's underneath or if i have to go with 33's. (prefer to get 35's). Also keeping cost in mind, as i really don't want to get very pricey. I've had BFG AT and MT's on a prior 2500. Tread wear was horrible. My best guess was d/t the 1 ton weight of the 2500. Help/Suggestions are welcome!! Thanks!
Old 10-13-2013, 10:27 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:387
You can get 35's on there no problem. You're gonna need a 1/4 inch spacer on those stock wheels to keep them from rubbing though. Let's see some pics when you're done.
Bilstein 5100's at 2.8. Fox 2.0 rears. MBC Razors with Nitto Ridge Grapplers. Airlift 1000 air bags. Mopar Tow mirrors. K&N air filter. Mopar rock deflector.
Old 10-23-2013, 12:50 AM
Cramer573 Cramer573 is offline
Vehicle: 2011 RAM 1500
Cramer573 is on a distinguished road
Originally Posted by Rugby1521 View Post
Hey all
I just ordered 35x12.50 trail grapplers for my 2011 outdoorsman. I'll let you know of any issues I encounter if they ever show up at my door.
Old 10-23-2013, 04:12 AM
northern2002's Avatar
northern2002 northern2002 is offline
Vehicle: 2002 dodge ram 2500
Trim Level: SLT plus
Color: gray
northern2002 is on a distinguished road
stick with 33in uless u plan on getting 4.56+ gears installed.
Old 10-23-2013, 06:12 AM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1125
You have 33s now. 35s will fit. You'll need a 1/4" spacer to eliminate rub at full lock. Unless you upgrade your wheels to something w at least a zero offset. As for gearing, there are plenty of ppl running 3:55 gears without issue. 3:92 gears would be better. Check your build sheet to know for sure what you have. If you don't have your build sheet, you can ask Chrysler for it.
285/65/20 BFG TA KO2s, Bilstein 5100s, Solid Fold tonneau, Rhino Liner, Husky Weatherbeaters, Magnaflow 18 muffler, Mufflex 5" tips, Carbon wrapped interior trim, Chime delete, Britax baby seat...
